Ethernet Products
5736 Discussions
Intel i226 Updating MAC Address
mingmou
I was wondering if it is possible to change the MAC address on the i226 after it has been set?
I've modified it with eeupdate , but it doesn't work
Is this intended behaviour? Is there a way to reset the i226 so we can change the MAC?
Amina_Sadiya
Hello Team,
Greetings from Intel!
Thank you for posting your query in the Intel Community. We sincerely apologize for the delay in our response. We have received your concern and want to assure you that assisting you is our top priority.
Could you kindly let us know if the issue has been resolved or if you require further assistance? Your prompt response will greatly assist us in diagnosing and resolving the issue as quickly as possible.
We truly appreciate your patience and understanding, and we look forward to hearing from you soon.
Amina
Amina_Sadiya
Hello Team,
Greetings for the day!
We are following up to check if you were able to find the information we requested. Kindly confirm at your earliest convenience, so that we can continue assisting you in resolving this matter.
If we don't hear back from you, we'll assume the issue has been resolved and will proceed to close the case.
Amina
Amina_Sadiya
Hello Team,
Thank you for contacting Intel.
This is the third follow-up regarding the reported issue. As we have not heard back from you, we'll assume the issue has been resolved and will proceed to close the case.
Amina
