Ethernet Products
5821 Discussions
Issue in launching sample-app with Intel Flexran
Maneesha_Perapalla
Hi Team,
We could launch Flexran sample-app on 2 different servers (one used as DU and another one as RU).
We followed this link: https://docs.o-ran-sc.org/projects/o-ran-sc-o-du-phy/en/latest/Setup-Configuration_fh.html
and added probing and dpdk binding for the VFs on both servers.
But we don't see any Rx counter and the Rx IQ samples shows (0,0) only.
VF[0] 0000:17:02.0
VF[1] 0000:17:02.1
IQ files size is 40 slots
app_xran_get_num_rbs: RAN [5G NR] nNumerology[0] nBandwidth[10] nAbsFrePointA[2645460] numRBs[52]
app_xran_get_num_rbs: RAN [5G NR] nNumerology[0] nBandwidth[10] nAbsFrePointA[2525460] numRBs[52]
Loading file ./usecase/mu0_10mhz/ant_0.bin to DL IFFT IN IQ Samples in binary format: Reading IQ samples from file: File Size: 1397760 [Buffer Size: 1397760]
from addr (0x7fe23007e010) size (1397760) bytes num (1397760)
Loading file ./usecase/mu0_10mhz/ant_1.bin to DL IFFT IN IQ Samples in binary format: Reading IQ samples from file: File Size: 1397760 [Buffer Size: 1397760]
from addr (0x7fe1ddd7a010) size (1397760) bytes num (1397760)
Loading file ./usecase/mu0_10mhz/ant_2.bin to DL IFFT IN IQ Samples in binary format: Reading IQ samples from file: File Size: 1397760 [Buffer Size: 1397760]
from addr (0x7fe1ddc24010) size (1397760) bytes num (1397760)
Loading file ./usecase/mu0_10mhz/ant_3.bin to DL IFFT IN IQ Samples in binary format: Reading IQ samples from file: File Size: 1397760 [Buffer Size: 1397760]
from addr (0x7fe1ddace010) size (1397760) bytes num (1397760)
Storing DL IFFT IN IQ Samples in human readable format to file ./logs/o-du-play_ant0.txt: from addr (0x7fe23007e010) size (1397760) IQ num (349440)
Storing DL IFFT IN IQ Samples in binary format to file ./logs/o-du-play_ant0.bin: from addr (0x7fe23007e010) size (698880) bytes num (698880)
Storing DL IFFT IN IQ Samples in human readable format to file ./logs/o-du-play_ant1.txt: from addr (0x7fe1ddd7a010) size (1397760) IQ num (349440)
Storing DL IFFT IN IQ Samples in binary format to file ./logs/o-du-play_ant1.bin: from addr (0x7fe1ddd7a010) size (698880) bytes num (698880)
Storing DL IFFT IN IQ Samples in human readable format to file ./logs/o-du-play_ant2.txt: from addr (0x7fe1ddc24010) size (1397760) IQ num (349440)
Storing DL IFFT IN IQ Samples in binary format to file ./logs/o-du-play_ant2.bin: from addr (0x7fe1ddc24010) size (698880) bytes num (698880)
Storing DL IFFT IN IQ Samples in human readable format to file ./logs/o-du-play_ant3.txt: from addr (0x7fe1ddace010) size (1397760) IQ num (349440)
Storing DL IFFT IN IQ Samples in binary format to file ./logs/o-du-play_ant3.bin: from addr (0x7fe1ddace010) size (698880) bytes num (698880)
TX: Convert S16 I and S16 Q to network byte order for XRAN Ant: [0]
TX: Convert S16 I and S16 Q to network byte order for XRAN Ant: [1]
TX: Convert S16 I and S16 Q to network byte order for XRAN Ant: [2]
TX: Convert S16 I and S16 Q to network byte order for XRAN Ant: [3]
System clock (rdtsc) resolution 2095077612 [Hz]
Ticks per us 2095
xran_init: MTU 9600
total cores 144 c_mask 0x21 core 5 [id] system_core 0 [id] pkt_proc_core 0x0 [mask] pkt_aux_core 0 [id] timing_core 5 [id]
xran_ethdi_init_dpdk_io: Calling rte_eal_init:wls_0 -c 0x21 -n2 --iova-mode=pa --socket-mem=8192 --socket-limit=8192 --proc-type=auto --file-prefix wls_0 -w 0000:00:00.0
EAL: Detected 128 lcore(s)
EAL: Detected 4 NUMA nodes
EAL: Auto-detected process type: PRIMARY
EAL: Multi-process socket /var/run/dpdk/wls_0/mp_socket
EAL: Selected IOVA mode 'PA'
EAL: Probing VFIO support...
EAL: VFIO support initialized
EAL: PCI device 0000:17:02.0 on NUMA socket 0
EAL: probe driver: 8086:154c net_i40e_vf
EAL: using IOMMU type 1 (Type 1)
initializing port 0 for TX, drv=net_i40e_vf
Port 0 MAC: 00 11 22 33 44 66
Port 0: nb_rxd 4096 nb_txd 4096
Checking link status portid [0] EAL: PCI device 0000:17:02.1 on NUMA socket 0
initializing port 1 for TX, drv=net_i40e_vf
Port 1 MAC: 00 11 22 33 44 66
Port 1: nb_rxd 4096 nb_txd 4096
Checking link status portid [1] vf 0 local SRC MAC: 00 11 22 33 44 66
vf 0 remote DST MAC: 00 11 22 33 44 55
vf 1 local SRC MAC: 00 11 22 33 44 66
vf 1 remote DST MAC: 00 11 22 33 44 55
FFT Order 10
app_xran_cal_nrarfcn: nCenterFreq[2650140] nDeltaFglobal[5] nFoffs[0] nNoffs[0] nNRARFCN[530028]
DL center freq 2650140 DL NR-ARFCN 530028
app_xran_cal_nrarfcn: nCenterFreq[2530140] nDeltaFglobal[5] nFoffs[0] nNoffs[0] nNRARFCN[506028]
UL center freq 2530140 UL NR-ARFCN 506028
XRAN front haul xran_mm_init
xran_sector_get_instances [0]: CC 0 handle 0x135f8c00
Handle: 0x118cd918 Instance: 0x135f8c00
init_xran [0]: CC 0 handle 0x135f8c00
Sucess xran_mm_init
nSectorNum 1
nSectorIndex[0] = 0
ru_0_cc_0_idx_0: [ handle 0x135f8c00 0 0 ] [nPoolIndex 0] nNumberOfBuffers 2240 nBufferSize 15696
CC:[ handle 0x135f8c00 ru 0 cc_idx 0 ] [nPoolIndex 0] mb pool 0x2ea4f6b00
ru_0_cc_0_idx_1: [ handle 0x135f8c00 0 0 ] [nPoolIndex 1] nNumberOfBuffers 35840 nBufferSize 24
CC:[ handle 0x135f8c00 ru 0 cc_idx 0 ] [nPoolIndex 1] mb pool 0x2e80d17c0
ru_0_cc_0_idx_2: [ handle 0x135f8c00 0 0 ] [nPoolIndex 2] nNumberOfBuffers 2240 nBufferSize 48416
CC:[ handle 0x135f8c00 ru 0 cc_idx 0 ] [nPoolIndex 2] mb pool 0x2e6b1f180
ru_0_cc_0_idx_3: [ handle 0x135f8c00 0 0 ] [nPoolIndex 3] nNumberOfBuffers 2240 nBufferSize 15696
CC:[ handle 0x135f8c00 ru 0 cc_idx 0 ] [nPoolIndex 3] mb pool 0x2e00f1e40
ru_0_cc_0_idx_4: [ handle 0x135f8c00 0 0 ] [nPoolIndex 4] nNumberOfBuffers 35840 nBufferSize 24
CC:[ handle 0x135f8c00 ru 0 cc_idx 0 ] [nPoolIndex 4] mb pool 0x2ddcccb00
ru_0_cc_0_idx_5: [ handle 0x135f8c00 0 0 ] [nPoolIndex 5] nNumberOfBuffers 2240 nBufferSize 48416
CC:[ handle 0x135f8c00 ru 0 cc_idx 0 ] [nPoolIndex 5] mb pool 0x2dc71a4c0
ru_0_cc_0_idx_6: [ handle 0x135f8c00 0 0 ] [nPoolIndex 6] nNumberOfBuffers 2240 nBufferSize 8192
CC:[ handle 0x135f8c00 ru 0 cc_idx 0 ] [nPoolIndex 6] mb pool 0x2d5ced180
ru_0_cc_0_idx_7: [ handle 0x135f8c00 0 0 ] [nPoolIndex 7] nNumberOfBuffers 2240 nBufferSize 15696
CC:[ handle 0x135f8c00 ru 0 cc_idx 0 ] [nPoolIndex 7] mb pool 0x2d48a5b40
init_xran_iq_content
xran_open: 5G NR Category A
xRAN open PRACH config: Numerology 0 ConfIdx 189, preambleFmrt 7 startsymb 0, numSymbol 2, occassionsInPrachSlot 7
PRACH: x 1 y[0] 0, y[1] 0 prach slot: 1 .. 6 ..
PRACH start symbol 0 lastsymbol 13
xran_open: interval_us=1000
XRAN_UP_VF: 0x0000
XRAN_CP_VF: 0x0001
MLog Info: virt=0x0000000000000000 size=0
Start XRAN traffic
Set debug stop 1, debug stop count 0
xran_timing_source_thread [CPU 5] [PID: 136561]
O-DU: thread_run start time: 12/09/21 10:19:42.000000004 UTC [1000]
Start C-plane DL 200 us after TTI [trigger on sym 3]
Start C-plane UL 440 us after TTI [trigger on sym 7]
Start U-plane DL 400 us before OTA [offset in sym -5]
Start U-plane UL 360 us OTA [offset in sym 6]
C-plane to U-plane delay 200 us after TTI
Start Sym timer 142857 ns
interval_us 1000
| Press 1 to start 5G NR XRAN traffic |
| Press 2 reserved for future use |
| Press 3 to quit |
[o-du][rx 0 pps 0 kbps 0][tx 0 pps 0 kbps 0] [on_time 0 early 0 late 0 corrupt 0 pkt_dupl 0 Total 0] IO Util: 66.31 %
[o-du][rx 0 pps 0 kbps 0][tx 0 pps 0 kbps 0] [on_time 0 early 0 late 0 corrupt 0 pkt_dupl 0 Total 0] IO Util: 66.27 %
[o-du][rx 0 pps 0 kbps 0][tx 0 pps 0 kbps 0] [on_time 0 early 0 late 0 corrupt 0 pkt_dupl 0 Total 0] IO Util: 66.32 %
[o-du][rx 0 pps 0 kbps 0][tx 0 pps 0 kbps 0] [on_time 0 early 0 late 0 corrupt 0 pkt_dupl 0 Total 0] IO Util: 66.30 %
[o-du][rx 0 pps 0 kbps 0][tx 43956 pps 43956 kbps 0] [on_time 0 early 0 late 0 corrupt 0 pkt_dupl 0 Total 0] IO Util: 66.92 %
[o-du][rx 0 pps 0 kbps 0][tx 108760 pps 64804 kbps 1089406] [on_time 0 early 0 late 0 corrupt 0 pkt_dupl 0 Total 0] IO Util: 67.08 %
[o-du][rx 0 pps 0 kbps 0][tx 173564 pps 64804 kbps 1134374] [on_time 0 early 0 late 0 corrupt 0 pkt_dupl 0 Total 0] IO Util: 67.03 %
[o-du][rx 0 pps 0 kbps 0][tx 238368 pps 64804 kbps 1134374] [on_time 0 early 0 late 0 corrupt 0 pkt_dupl 0 Total 0] IO Util: 67.03 %
[o-du][rx 0 pps 0 kbps 0][tx 303172 pps 64804 kbps 1134374] [on_time 0 early 0 late 0 corrupt 0 pkt_dupl 0 Total 0] IO Util: 67.02 %
[o-du][rx 0 pps 0 kbps 0][tx 367976 pps 64804 kbps 1134374] [on_time 0 early 0 late 0 corrupt 0 pkt_dupl 0 Total 0] IO Util: 67.03 %
[o-du][rx 0 pps 0 kbps 0][tx 432784 pps 64808 kbps 1134374] [on_time 0 early 0 late 0 corrupt 0 pkt_dupl 0 Total 0] IO Util: 67.02 %
[o-du][rx 0 pps 0 kbps 0][tx 497588 pps 64804 kbps 1134374] [on_time 0 early 0 late 0 corrupt 0 pkt_dupl 0 Total 0] IO Util: 67.02 %
[o-du][rx 0 pps 0 kbps 0][tx 562392 pps 64804 kbps 1134374] [on_time 0 early 0 late 0 corrupt 0 pkt_dupl 0 Total 0] IO Util: 67.02 %
[o-du][rx 0 pps 0 kbps 0][tx 627196 pps 64804 kbps 1134374] [on_time 0 early 0 late 0 corrupt 0 pkt_dupl 0 Total 0] IO Util: 67.01 %
[o-du][rx 0 pps 0 kbps 0][tx 692004 pps 64808 kbps 1134374] [on_time 0 early 0 late 0 corrupt 0 pkt_dupl 0 Total 0] IO Util: 67.03 %
STOP:[1639045200.000000078]
Closing timing source thread...
[o-du][rx 0 pps 0 kbps 0][tx 710236 pps 18232 kbps 1134374] [on_time 0 early 0 late 0 corrupt 0 pkt_dupl 0 Total 0] IO Util: 67.01 %
get_xran_iq_content
Closing l1 app... Ending all threads...
Failed at xran_mm_destroy, status -2
Dump IQs...
RX: Convert S16 I and S16 Q to cpu byte order from XRAN Ant: [0]
RX: Convert S16 I and S16 Q to cpu byte order from XRAN Ant: [1]
RX: Convert S16 I and S16 Q to cpu byte order from XRAN Ant: [2]
RX: Convert S16 I and S16 Q to cpu byte order from XRAN Ant: [3]
Storing UL FFT OUT IQ Samples in human readable format to file ./logs/o-du-rx_log_ant0.txt: from addr (0x7fe1dd978010) size (1397760) IQ num (349440)
Storing UL FFT OUT IQ Samples in binary format to file ./logs/o-du-rx_log_ant0.bin: from addr (0x7fe1dd978010) size (698880) bytes num (698880)
Storing UL FFT OUT IQ Samples in human readable format to file ./logs/o-du-rx_log_ant1.txt: from addr (0x7fe1dd822010) size (1397760) IQ num (349440)
Storing UL FFT OUT IQ Samples in binary format to file ./logs/o-du-rx_log_ant1.bin: from addr (0x7fe1dd822010) size (698880) bytes num (698880)
Storing UL FFT OUT IQ Samples in human readable format to file ./logs/o-du-rx_log_ant2.txt: from addr (0x7fe1dd6cc010) size (1397760) IQ num (349440)
Storing UL FFT OUT IQ Samples in binary format to file ./logs/o-du-rx_log_ant2.bin: from addr (0x7fe1dd6cc010) size (698880) bytes num (698880)
Storing UL FFT OUT IQ Samples in human readable format to file ./logs/o-du-rx_log_ant3.txt: from addr (0x7fe1dd576010) size (1397760) IQ num (349440)
Storing UL FFT OUT IQ Samples in binary format to file ./logs/o-du-rx_log_ant3.bin: from addr (0x7fe1dd576010) size (698880) bytes num (698880)
PRACH: Convert S16 I and S16 Q to cpu byte order from XRAN Ant: [0]
PRACH: Convert S16 I and S16 Q to cpu byte order from XRAN Ant: [1]
PRACH: Convert S16 I and S16 Q to cpu byte order from XRAN Ant: [2]
PRACH: Convert S16 I and S16 Q to cpu byte order from XRAN Ant: [3]
Storing PRACH FFT OUT IQ Samples in human readable format to file ./logs/o-du-prach_log_ant0.txt: from addr (0x7fe1dd127010) size (4515840) IQ num (1128960)
Storing PRACH FFT OUT IQ Samples in binary format to file ./logs/o-du-prach_log_ant0.bin: from addr (0x7fe1dd127010) size (2257920) bytes num (2257920)
Storing PRACH FFT OUT IQ Samples in human readable format to file ./logs/o-du-prach_log_ant1.txt: from addr (0x7fe1dccd8010) size (4515840) IQ num (1128960)
Storing PRACH FFT OUT IQ Samples in binary format to file ./logs/o-du-prach_log_ant1.bin: from addr (0x7fe1dccd8010) size (2257920) bytes num (2257920)
Storing PRACH FFT OUT IQ Samples in human readable format to file ./logs/o-du-prach_log_ant2.txt: from addr (0x7fe1dc889010) size (4515840) IQ num (1128960)
Storing PRACH FFT OUT IQ Samples in binary format to file ./logs/o-du-prach_log_ant2.bin: from addr (0x7fe1dc889010) size (2257920) bytes num (2257920)
Storing PRACH FFT OUT IQ Samples in human readable format to file ./logs/o-du-prach_log_ant3.txt: from addr (0x7fe1dc43a010) size (4515840) IQ num (1128960)
Storing PRACH FFT OUT IQ Samples in binary format to file ./logs/o-du-prach_log_ant3.bin: from addr (0x7fe1dc43a010) size (2257920) bytes num (2257920)
[root@localhost app]#
Can anyone help in capturing the packets while running sample-app?
Or is there any change required?
Thank you.
