Ethernet Products
5704 Discussions
Killer E5000B 5 Gigabit locked at 100MB
Jonty_NZ
I've seen this issue with other Killer NICs and have been through all the following steps:
- updated drivers through DSA and all up to date
- can't find Killer Control Centre but get pushed to Killer Performance Suite, it does not solve my problem
- done network resets
- tweak properties of cards
- swapped out cables, routers etc
- checked BIOS
- Intels onile help doesn't provide drop down for this card
I'm now exhausted/angry and can't seem to fix this.
Help!
JeanetteC_Intel
Hello Jonty_NZ,
Thank you for sharing the log file. Please proceed with the following steps below:
1) Update the BIOS firmware to the latest version (7E34v2A70). It's best to reach out your motherboard manufacturer's support team with this critical update.
2) Please also try installing the OEM driver for the LAN driver, version 36.24.12134
Let me know how it goes.
JeanetteC.
1ntellNeedNewCEO
Same problem, seems it's a common issue among other things. I have updated my driver's, cat 6 proven cable, tried switching from auto negotiation to 1gbps, nothing.
JeanetteC_Intel
Hello 1ntellNeedNewCEO,
I understand that you are encountering a similar issue, however, I kindly request that you create a new thread for your case. This will allow us to focus on your specific problem and provide you with better assistance.
Sincerely,
JeanetteC.
JeanetteC_Intel
Hello Jonty_NZ.,
I apologize for the difficulties you're facing with your Killer NIC. To help address the issue, please share your system configuration by downloading the Intel® System Support Utility for Windows* software. Once downloaded, launch SSU.exe.
  • Click Scan.
  • Click Save. *Attach the SSU log file as you reply.
I hope to hear from you soon.
JeanetteC.
DonRSM
This is the ethernet port on my MSI Gaming Wifi Plus mobo. I have updated the BIOS and ethernet drivers and the internet connection still randomly drops. I have made all the changes to keep the connection active to no avail. I'm also wondering if I can avoid the Killer ethernet drivers and install generic ethernet driver instead.
JeanetteC_Intel
Hello DonRSM,
I understand you're experiencing issues with the same component. Please create a new thread for your case so we can concentrate on your specific problem and offer more effective assistance.
Sincerely,
JeanetteC.
Jonty_NZ
Hi Jeanette,
Thanks for your help.  I have uploaded the scan output.
JeanetteC_Intel
Hello Jonty_NZ,
JeanetteC.
Jonty_NZ
Thanks Jeanette,
BIOS update fixed it!
JeanetteC_Intel
Hello Jonty_NZ,
I'm pleased to hear that the BIOS update resolved the issue. If you have any future questions or concerns, please feel free to reach out by submitting a new question, as this thread will no longer be monitored.
Sincerely,
JeanetteC.
