We are using following SRIOV NICs in our platforms.
[root@appliance-1:Active] ~ # lspci -d 8086:1893
ec:00.4 Ethernet controller: Intel Corporation Ethernet Connection E822-C/X557-AT 10GBASE-T (rev 11)
ec:00.5 Ethernet controller: Intel Corporation Ethernet Connection E822-C/X557-AT 10GBASE-T (rev 11)
ec:00.6 Ethernet controller: Intel Corporation Ethernet Connection E822-C/X557-AT 10GBASE-T (rev 11)
ec:00.7 Ethernet controller: Intel Corporation Ethernet Connection E822-C/X557-AT 10GBASE-T (rev 11)
[root@appliance-1:Active] ~ # lspci -d 8086:1892
ec:00.0 Ethernet controller: Intel Corporation Ethernet Controller E822-C for SFP (rev 11)
ec:00.1 Ethernet controller: Intel Corporation Ethernet Controller E822-C for SFP (rev 11)
ec:00.2 Ethernet controller: Intel Corporation Ethernet Controller E822-C for SFP (rev 11)
ec:00.3 Ethernet controller: Intel Corporation Ethernet Controller E822-C for SFP (rev 11)
The nics are binded to iavf drivers. please find the driver details.
[root@appliance-1:Active] ~ # modinfo iavf
filename: /lib/modules/3.10.0-1160.71.1.F5.1.1.1.el7_8.x86_64/updates/drivers/net/ethernet/intel/iavf/iavf.ko
version: 4.3.19
license: GPL
description: Intel(R) Ethernet Adaptive Virtual Function Driver
author: Intel Corporation, <linux.nics@intel.com>
alias: i40evf
retpoline: Y
rhelversion: 7.9
srcversion: 58C0C08BF00AE634467AA8F
alias: pci:v00008086d00001889sv*sd*bc*sc*i*
alias: pci:v00008086d000037CDsv*sd*bc*sc*i*
alias: pci:v00008086d00001571sv*sd*bc*sc*i*
alias: pci:v00008086d0000154Csv*sd*bc*sc*i*
depends: ptp,auxiliary
vermagic: 3.10.0-1160.71.1.F5.1.1.1.el7_8.x86_64 SMP mod_unload modversions
Scenario:
On the platform/host, We have created a LACP LAG on the PFs.
Creating a container allocating a vf from each PF using sriov CNI and creating the LACP using the bond CNI. We see that interfaces and Bond is created successfully inside the container.
We have followed this doc to configure LACP inside the container:
https://www.intel.com/content/www/us/en/developer/articles/technical/bond-cni.html
Issue:
We have observed that LACP is not formed properly with VFs inside the container.
The traffic doesn't passthrough from the container.
Please let us know if you need any more details on the config and setup.
- Tags:
- LACP and SRIOV
Hello Nag08,
Thank you for posting in the Intel Community. We sincerely apologize for the delay in our response. We have received your concern and would like to assure you that assisting you is our top priority.
Could you kindly let us know if the issue has been resolved, or if you require further assistance from us? Your prompt response will greatly help us in diagnosing and resolving the issue as quickly as possible.
We appreciate your patience and understanding, and we look forward to hearing from you soon.
Pujeeth_intel
Hello Nag08,
Thank you for contacting Intel.
This is the first follow-up regarding the issue you reported to us.
We wanted to inquire whether you had the opportunity to review the plan of action (POA) we provided.
Feel free to reply to this email, and we'll be more than happy to assist you further.
Pujeeth
Hello Nag08,
Greetings!
We will proceed to close this case. If you find that you still required assistance, we kindly request you to respond to the case. This will allow us to either reopen the current case or initiate a new one.
Pujeeth_Intel
