Ethernet Products
5672 Discussions
Legacy Intel lan driver
fortis
I have an older Gigabyte mobo Gigabyte G1.Assassin 2. The only lan driver I could find was "Bigfoot Killer Ethernet Controller" (Bigfoot Killer E2100 chip)
for Win XP 64 on Giga site: "mb_driver_lan_bigfoot.exe" 74.404 GB (2012). https://www.gigabyte.com/Motherboard/G1Assassin-2-rev-10/support#support-dl-driver-lan
The problem: when I do large file transfer from PC over lan (over 2 GB), network goes down and must reboot to recover the lan.
Can you direct me to an Intel Bigfoot legacy driver that would work with Windows 10?
I need a recommendation and url for an Intel legacy lan driver that would work with Windows 10 and with Bigfoot Killer E2100 chip.
IntelSupport
Community Manager
Hi fortis,
Regarding your inquiry, we recommend you to check the link below for list of Intel® Killer™ Windows 10 driver compatible model.
Intel® Killer™ Performance Suite
https://www.intel.com/content/www/us/en/download/19779/intel-killer-performance-suite.html
We also recommend you to contact and get a consult from OEM regarding suitable driver, which is Gigabyte itself. As your system manufacturer may have pre-installed the driver on your system to enable OEM-specific features. Which means their drivers may have been bit optimized or customized to be used with your system.
Fariz_Intel
IntelSupport
Community Manager
Hi fortis,
If you have additional questions or clarifications, feel free to let us know.
We will contact you again within 3 business day for a follow-up. Looking forward to receiving your reply. Thanks.
Fariz_Intel
IntelSupport
Community Manager
Hi fortis,
Since we have not seen an update for several days, if you need any additional information, please submit a new question as this thread will no longer be monitored.
Fariz_Intel
