Ethernet Products
5879 Discussions
Missing Advanced Tab
I recently purchased an Intel Pro/1000 MT server NIC and installed it on an Intel DG31PR motherboard running Windows Home Server. I went to Intel's website and downloaded and installed the latest drives for the NIC, however no matter what I do I cannot get the advanced TAB to show under the properties for the adapter. Am I missing something or does this card not have any advanced properties?
JUSTIN_W_Intel
We've seen this if you're logging in via Terminal Services. It has to do with User Permissions in Windows* If you are trying to configure it via Terminal Services try this solution:
http://www.intel.com/support/network/sb/CS-020166.htm http://www.intel.com/support/network/sb/CS-020166.htm
Otherwise, if you're seeing this issue while physicaly infront of the computer then it could be a couple other things.
  • During install ensure you have Intel(R) Proset for Windows* Device Manager is selected.
If you did that already and it's still not showing, then:
  • Ensure WMI service is started
Hope that helps.
Justin
Thank you very much! That resolved the problem.
