Ethernet Products
5705 Discussions
Missing Network Drivers
DMpot
Good Morning
I have a PC with network driver issue.
the manufacture is "Mercer Pro-Efficient Extreme"
Can you provide me with the drivers for it as the once I got from internet are nor working.
I have attached a photo of a missing driver, please help ASAP..,..!!!
DMpot
Additional info
Mecer Pro-Efficient Extreme: DQ57TM
Model Range:PTM-560
st4
New Contributor III
Hi 2piec3,
Please check with your system vendor for the customized driver. If you need driver for onboard NIC on Intel board, you can visit http://downloadcenter.intel.com/ http://downloadcenter.intel.com the search the board model to obtain the generic driver.
It is recommended to contact the system vendor for driver if you are using a third party system.
wb
