Additional info
Mecer Pro-Efficient Extreme: DQ57TM
Model Range:PTM-560
Hi 2piec3,
Please check with your system vendor for the customized driver. If you need driver for onboard NIC on Intel board, you can visit http://downloadcenter.intel.com/ http://downloadcenter.intel.com the search the board model to obtain the generic driver.
It is recommended to contact the system vendor for driver if you are using a third party system.
wb
Topic Options
