Ethernet Products
5580 Discussions
Multicast, Network Bridge, Server 2019 and I350-T2
Tom_T
Hi
I have a Intel Ethernet Server Adapter I350-T2 and a Server 2019 install.
When I enable a network bridge it seems that Multicast is stopped. How do I make sure that multicast packages move between the two ports?
CHeers
Tom
Mike_Intel
Hello Tom_T,
For us to further check the issue, please provide the following details.
  1. Can you share a screenshot of the issue?
  2. Are you using a PCIe I350-T2 ot is it onboard?
  3. What is the brand and model of your motherboard/system?
  4. Can you share the link of the latest network driver that you are using?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel® Customer Support
Tom_T
Hi
thanks for answering.
No, no screenshot.
Yes, PCIe I350-T2 in a Dell Precision 3640 with i9-10900K and Nvidia P2200
I use latest Intel drivers, showing as 12.18.13.0
Bridge is set 192.168.20.140. I can ping the "downstream" device connected to #2 NIC which is 192.168.20.138. And I can ping all other IPs in the network.
I can remote desktop into both devices 192.168.20.140 and x.138
Firewall is turned off. Both are running Server 2019.
When I connect x.138 and multicast app on x.140 discovers x.138. But when plugged into bridge x.138 is not detected.
Tom
Tom_T
Sorry, last two sentences unclear. When I connect x.138 with a switch, all work, if I connect in #2 port, then only ping works but not multicast detection...
Mike_Intel
Hello Tom_T,
Thank you for the quick reply. Before we proceed, can you send some photos of the I350-T2 PCIe card on both sides for us to validate the markings.
Michael L.
Tom_T
Thank you for YOUR quick reply.
I hope these pics will do, if not, I can try making sharper pics.
Best regards
Tom
Mike_Intel
Hello Tom_T,
Thank you for the quick reply. Upon initial inspection, your card does not have the YottaMark* and BradyID* Stickers. Please check the link below for more details about those stickers.
https://www.intel.com/content/www/us/en/support/articles/000007074/ethernet-products/gigabit-ethernet-adapters-up-to-2-5gbe.html
Upon checking the markings, as per the part number. Your network card is an OEM unit from Dell. Dell may have altered the features of this card so for further assistance, kindly contact Dell and coordinate the issue with them.
Michael L.
Mike_Intel
Hello Tom_T,
I hope you're having a wonderful day. I am just sending a soft follow up hoping that you are now contacting Dell for further assistance since they are the best team who can further help you. We will wait for your reply.
Michael L.
Tom_T
Thanks Michael, I was not aware that you still monitor this ticket. Appreciated.
I will follow up with Dell. While I did not buy from them, the card runs in a Dell Workstation still under warranty. So they might be able to help.
Thanks again
Tom
Mike_Intel
Hello Tom_T,
Thank you for the update and understanding. I am also glad that we were able to direct you to the correct support group.
Since you are now going to talk to Dell. we will now close this case/thread.
Thank you and stay safe.
Michael L.
