Ethernet Products
5716 Discussions
Network interface firmware update failure
AKhud3
My motherboard is Supermicro X11SPW-CTF. There is dual LAN with 10GBase-T with Intel® X722 + X557 on board. I have tried flash original network interfaces firmware version 3.45 to newer 3.50 using nvmupdatew64e utility. And I have power lost during update. Both interfaces doesn't work now. Is it possible to restore workability of the network interfaces? Here is log of my recovery tries:
D:\nvmupdatew64e.exe -i -o inv_xml.txt -l inv.txt
D:\type inv.txt
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.32.20.30
Copyright (C) 2013 - 2018 Intel Corporation.
Inventory
[00:025:00:00]: Intel(R) Ethernet Connection X722 for 10GBASE-T
Flash inventory started.
Shadow RAM inventory started.
Error:  LAN MAC address cannot be read.
Shadow RAM inventory finished.
Flash inventory failed.
DEVICE IS IN RECOVERY MODE!
Vendor         : 8086
Device         : 37CC
Subvendor       : 8086
Subdevice       : 35CF
Revision        : 8
LAN MAC        : 000000000000
Alt MAC        : 000000000000
SAN MAC        : 000000000000
ETrackId        : 00000000
NVM Version      : n/a(n/a)
PBA          : n/a
VPD status       : Not set
VPD size        : 0
NVM update       : No config file entry
 checksum       : Invalid
OROM update      : No config file entry
 CIVD         : 0.0.0
D:\type inv_xml.txt
<?xml version="1.0" encoding="UTF-8"?>
<DeviceInventory lang="en">
    <Instance vendor="8086" device="37CC" subdevice="35CF" subvendor="8086" bus="25" dev="0" func="0" PBA="n/a" port_id="Port 1 of 1" display="Intel(R) Ethernet Connection X722 for 10GBASE-T">
        <Module type="NVM" recovery="1" version="00000000">
        </Module>
    </Instance>
</DeviceInventory>
D:\nvmupdatew64e.exe -l update.txt
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [**-.......]
Num Description             Ver.(hex) DevId S:B  Status
01) Intel(R) Ethernet Connection X722   n/a(n/a) 37CC 00:025 RECOVERY
  for 10GBASE-T                        available
Options: Adapter Index List (comma-separated), [A]ll, e[X]it
Enter selection:A
Update in progress. This operation may take several minutes.
  for 10GBASE-T                        failed
Tool execution completed with the following status: Cannot restore manufacturing data.
Press any key to exit.
D:\type update.txt
Config file read.
Inventory
Update
    Flash update started.
Error:  Flash update failed.
D:\type 000000000000\.rollback.cfg
;File generated automatically by NVMUpdate tool
CONFIG VERSION: 1.13.0
BEGIN DEVICE
DEVICENAME: Intel(R) Ethernet Connection X722 for 10GBASE-T
VENDOR: 8086
DEVICE: 37CC
SUBVENDOR: 8086
SUBDEVICE: 35CF
NVM IMAGE: 000000000000\000000000314.bin
IMAGE DOWNGRADE: TRUE
BEGIN PHY: ID=1540242
IMAGE: 000000000000\000000000314_phy0.bin
DOWNGRADE: TRUE
END PHY
END DEVICE
D:\nvmupdatew64e.exe -r -m 000000000000 -l rollback.txt
D:\type rollback.txt
Warning: Device with MAC address 000000000000 not found.
Please help!
Thanks in advance,
Anton.
Mike_Intel
Hello AKhud3, Thank you for posting in Intel Ethernet Communities. Since both Intel® X722 and Intel® X557 are on board, you may try updating the BIOS of the board. Regarding the BIOS update, please contact Supermicro on how to update the BIOS. If you have questions, please let us know. Best regards, Michael L. Intel Customer Support Under Contract to Intel Corporation
Mike_Intel
AKhud3
Hi Michael.
Thank You for the answer. Supermicro support sent me special tool for recovering. And it's ok now.
Anton.
sdillingham
Do you by chance still have the file from supermicro, i am having the same issue
Gael
Today I have the same problem with my network card, but this is not on supermicro but on intel S2600WF0 board. Do you have same tool regarding intel products?
Thanks for help
mohdabdulasim
I have the same problem with my network card intel x722, while upgrading firmware PC got stuck and after restart the PC network card disappear. Unbale to upgrade / recover the firmware. Could you please assist me to recovery procedure or atleast working back my ethernet adaptor. Currently  PC OS is Windows 11 224H2.
Thanks for help
Gael
When the card is stuck, there are no solutions. I resolve issue by downgrading the bios of server to previous and update again to latest.
I was surprised but the bios of server has the firmware of the card included in.
Hope it will help,
