Ethernet Products
5720 Discussions
Network link is disconnected on startup
GGang1
I have a Intel(R) I210 Gigabit Network Connection on my system, and I have the problem, that there is a huge (24s) delay between startup and Network link connected.
at 16:54:35:
The Intel(R) PROSet Monitoring Service service entered the running state.
at 16:54:36
Intel(R) 82579LM Gigabit Network Connection Network link is disconnected (this is ok, because there is no cable)
at 16:54:36
Intel(R) I210 Gigabit Network Connection Network link is disconnected. (this is not ok, because there is a cable connected on it)
at 16:54:59:
Intel(R) I210 Gigabit Network Connection Intel SmartSpeed has downgraded the link speed from the maximum advertised.
at 16:54:59:
Intel(R) I210 Gigabit Network Connection Network link has been established at 100Mbps full duplex.
If I plug in the cable on the other network adapter (Intel 825879LM, the network adapter is conneceted instantly).
I'm using the network driver Intel® Network Adapter Driver for Windows 7* Version 23.2 (latest).
Hello Grex,
Thank you for posting in Intel Wired Ethernet Communities. Is the I210 Ethernet controller onboard? To give us a better idea of the drivers and configurations for the adapter please provide https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- System Support Utility logs. This will not collect any personal information.
  • Download and run the .exe from the link above
  • Check "everything" then click "scan"
  • When scan is finished click "next"
  • Save the log and attach it to a post
The https://www.intel.com/content/www/us/en/support/articles/000008490/software/software-applications.html FAQs have additional information about this utility. If you have any questions please do not hesitate to contact us.
Daniel D
Intel Customer Support
Hello Grex,
Please let us know if you still require assistance. If you have any questions about the requested logs please inform us.
Daniel D
Hello Grex,
Please let us know if you have any questions.
Daniel D
