Ethernet Products
5821 Discussions
Not able to test cryptographic performance using crypto_aesni_mb
Md_Raizz
Trying to test cryptography performance virtual crypto AES-NI MB PMD using below command,
sudo ./dpdk-test-crypto-perf -c 0xf -n 4 --vdev crypto_aesni_mb -- --ptest throughput --devtype crypto_aesni_mb --optype cipher-then-auth --cipher-algo aes-cbc --cipher-op encrypt --cipher-key-sz 16 --auth-algo sha1-hmac --auth-op generate --auth-key-sz 64 --digest-sz 16 --total-ops 100000 --burst-sz 32 --buffer-sz 2048
Using below link I followed steps to enable the virtual crypto
https://doc.dpdk.org/guides-20.11/cryptodevs/aesni_mb.html
https://dpdk-test-plans.readthedocs.io/en/latest/crypto_perf_test_plan.html
EAL: failed to parse device "crypto_aesni_mb"
EAL: Unable to parse device 'crypto_aesni_mb'
our platform supports AES ni
grep aes -o /proc/cpuinfo
aes
aes
kindly provide the solution,
thanks & regards,
Raizz
Dineshbabu
Hi Md_Raizz,
Greetings!
Please let me know if there is any validation that you are performing on the adapter.
Please help us with the adapter model.
Dinesh
Md_Raizz
Hi Dinesh,
Thanks for your reply.
I am testing on both mellanox connect-X 5 and alveo u200 accelerator cards.
In both cases faces same issue
kindly provide the solution.
Thanks & Regards,
Raizz
IntelSupport
Community Manager
Hello Mohamed,
Greetings for the day !
I wanted to bring to your attention that your using Nvidia And AMD.
We request you to reach out Original Equipment Manufacturer (OEM) for further assistance.
Their expertise and resources may be instrumental in resolving the issue .
Varsha
