Ethernet Products
5881 Discussions
Outdated Intel I350‑T4 Driver (e1r65x64.sys) Causing System Freezes and Hardware Resets
Sysadmin_random
I am experiencing recurring system freezes and hardware resets related to the Intel I350‑T4 network adapter on a Windows Server 2016 system. The issue appears to be caused by the outdated driver e1r65x64.sys, which is currently the latest version available for this OS.
Symptoms observed:
  • Random system freezes under network load
  • Network adapter resets
  • Event Viewer repeatedly logs Event ID 10400 (NDIS)
  • After each occurrence, the system recovers but the network interfaces temporarily drop
This behavior strongly suggests that the existing driver for the I350‑T4 on Windows Server 2016 is no longer stable or compatible with recent system updates.
Environment details:
  • Hardware: Intel I350‑T4
  • OS: Windows Server 2016 (fully updated)
  • Driver file: e1r65x64.sys
  • Issue: Hardware reset / NDIS Event 10400
  • No updated driver package available for WS2016
I would like to know:
  1. Is Intel aware of stability issues with the current I350‑T4 driver for Windows Server 2016?
  2. Is there an updated or alternative driver available that resolves these problems?
  3. If Windows Server 2016 is no longer supported for this adapter, is there an official Intel statement confirming this?
Any guidance or updated driver package would be greatly appreciated, as this is affecting a production environment.
Thank you.
MACM
Hi Sysadmin_random,
Greetings of the day.
Hope you are doing great.
Could you please share us the below details.
1) Front and back picture of the NIC card.
2) Was this NIC card came along with the system or was it purchased it separately.
3) Please share us the completed system information.
We will proceed further accordingly once we receive the above information.
Mohammed Ali CM
MACM
Hi Sysadmin_random,
This is the follow up. Could you please share us the below details.
3) Please share us the complete system information.
Mohammed Ali CM
Sysadmin_random
Hi, sorry for the delay and thank you for your reply.
Regarding point 1:
Unfortunately, I do not have physical access to the server, as it is located in a remote datacenter. The system is managed remotely via Lenovo XClarity. Because of this, I cannot take front and back pictures of the NIC card.
However, I can provide all available identification details from XClarity / system inventory (NIC model, part number, FRU, firmware version, etc.) if that helps.
Regarding point 2:
The Intel I350‑T4 NIC came pre‑installed with the system by the server vendor (Lenovo). It was not purchased or installed separately.
Regards!
Sreelakshmi1
Hi Sysadmin_random,
Thank you for your response. Kindly share the SSU logs for us to check further.
Please refer below article for reference.
https://www.intel.com/content/www/us/en/support/articles/000008563/ethernet-products.html
Sreelakshmi
Sysadmin_random
Hi, I've attached the logs, thanks!
Shankith
Hello Sysadmin_random,
Thank you for sharing the SSU logs.
We are checking internally. We will get back to you once we have an update.
Shankith K P
​​​​​​​Intel Customer Support Technician
pujeeth
Greetings!
To help us better understand the cause of the issue, we kindly request you to confirm whether this behavior started immediately after updating to this driver, or if it coincided with any other system changes (such as Windows updates, BIOS/firmware updates, or hardware changes).
Pujeeth_Intel
Sysadmin_random
Good morning, there are no changes or updates; it can only be commented that it coincides with backup processes carried out with Commvault, but it must be said that the backup is performed daily and only fails on Saturday night to Sunday every few weeks.
pujeeth
Greetings!
Thank you for your response. We are reviewing this case and will get back to you with an update as soon as possible.
Pujeeth_Intel
Dineshbabu
Hi Sysadmin_random,
Greetings!
Thank you for your patience. Based on the SSU log the current driver version is 12.15.184.0 and the latest driver version for i350 is e1r - 14.0.6.0.
We recommend updating the driver and let us know the status.
Please find the driver package link below, along with a screenshot of the version details for Windows Server 2016.
https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html
Dinesh
Sysadmin_random
Hi!
Thanks for the reply; what I wanted to do was update the firmware from XClarity, would that be a good option? I've attached an image of the driver and its version.
Regards!
Dineshbabu
Hi Sysadmin_random,
Thank you for your response. Please allow us some time to review the details and we will get back with an update shortly.
Dinesh
Dineshbabu
Hi Sysadmin_random,
Greetings!
Thank you for your patience. We recommend that you try updating, but we do not have the steps since this is a Lenovo xClarity environment.
Dinesh
MACM
Thank you for contacting Intel.
This is the follow-up regarding the reported issue. We're eager to ensure a swift resolution and would appreciate any updates or additional information you can provide.
Please feel free to respond to this email at your earliest convenience.
Mohammed Ali CM
MACM
This is the third follow-up regarding the reported issue. We're committed to ensuring a swift resolution and would greatly appreciate any updates or additional information you can provide.
If we don't hear back from you soon, we'll assume the issue has been resolved and will proceed to close the case.
Mohammed Ali CM
