Ethernet Products
5861 Discussions
updating ETrackID for I210T1 'Intel Corporation Ethernet Server Adapter I210-T1'
EJ_FMT
We are working with the I210 NIC.
We found that some of these components have different ETrackIDs:
0x800006eb
0x800006ed
(Q: what is the 'middle number' to firmware_version? A: the ETrackID)
How to Check the Firmware Version of Intel® Ethernet Adapters under...
(Q: why do 2 different NIC units have different ETrackID?  A: based on model and NVM version)
Why Is the ETrackID of an Ethernet Adapter Different than Another One...
[root@f43afaa2c3b9 ~]# ethtool -i eth2
driver: igb
version: 5.3.0-k
firmware-version: 3.25, 0x800006ed, 1.3220.0
bus-info: 0000:c3:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: no
[root@f43afaa2c3b9 ~]# lspci -s c3:00.0
c3:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
[root@ ~]#
[root ~]# lspci -s c3:00.0
Based on this help document, the ETrackID can be replaced by using nvmupdate64e and a config file:
1579376_332161_Intel+Ethernet+NVM+Update+Tool+Quick+Usage+Guide+for+Linux.pdf
However we are using bootutil64e to flash the NIC:
[root]# md5sum bootutil64e
354f78ddd0e61581b275692c8b85206d  bootutil64e
[root]# md5sum BootIMG.FLB
a8c5e9ea0f270060be0503014493a068  BootIMG.FLB
## running the flash
./bootutil64e -nic=1 -up=combo -file=BootIMG.FLB -quiet
./bootutil64e -nic=1 -BOOTENABLE=DISABLED
## reboot for new version to take effect
It doesnt look like bootutil64e supports using a config file.
Our issue is that we need the string from ethtool 'firmware_version : ...' to match on all same-config products that are assembled with this NIC.
We may redesign the failing test to ignore this portion of the string, confirming only NVM version (3.25) and combo image version (1.3220.0).
But we were wondering if there is a way to update the ETrackID using bootutil64e.
Can ETrackID be updated using bootutil64e?
Is the I210 NIC supported by nvmupdate64e?
Thanks for any assistance.
Sachinks
Hello EJ_FMT,
From your query, we understand that you wish to match the string from ethtool on all the systems assembled with I210 NIC and you wish to know if the ETrackID can be updated using bootutil64e.
As your query is design related and as we see that your organization has a CNDA with us, we request you to create an IPS (Intel premier support) case for this concern.
You can follow the steps given in the below link to create an IPS case with us.
Link : https://www.intel.com/content/www/us/en/support/articles/000057045/ethernet-products.html
Please don’t hesitate to contact us for any further assistance.
Thank you for using Intel products and services.
Sachin KS
Sachinks
Hello EJ_FMT,
Sachin KS
EJ_FMT
Got it solved.
The trick was to use 'eeupdate64e /gui' to modify the ETrackID in the EEPROM.
EEUPDATE v5.35.23.02
Thank you!
Marking 'solved'.
vish1
Hello EJ_FMT,
Greetings for the day!!
Thank you for the update.
We are glad to hear that the issue has been resolved. We also appreciate you sharing the solution with us this information is very helpful and valuable.
Please feel free to reach out if you need any further assistance.
Vishal Shet P
Sachinks
Hello EJ_FMT,
As you have confirmed that the issue is resolved, we will go ahead and close this thread for now.
Sachin KS
