Ethernet Products
5744 Discussions
PTP boundary clock (BC) on X710
SSass3
I'm trying to run the PTP boundary clock on the 710 chip using the linuxPTP.
Each interface has its own clock. I need to sync between these two clock interfaces.
How can I sync these two clocks or using the same clock for both interfaces? look like phc2sys does not do the job.
Caguicla_Intel
Hello SSass3,
Please allow us to check on your query. We will give you an update as soon as possible but no later than 3 business days.
Hoping for your kind patience.
Crisselle C
Intel® Customer Support
Caguicla_Intel
Hello SSass3,
Good day!
We sincerely apologize for the delay on this matter as we are thoroughly checking on this. Please give us more time to look into this. Rest assured that we will give you an update as soon as there is any findings but not later than 3 business days.
Thank you for your kind understanding.
Crisselle C
Caguicla_Intel
Hello SSass3,
I hope you are doing great!
After series of validation, please be informed that it is best to report your inquiry to http://linuxptp.sourceforge.net/ as they are the best source of support. You may report your concerns with the software to the linuxptp-users mailing list from the link below.
https://sourceforge.net/projects/linuxptp/lists/linuxptp-users
Let us know if you have additional questions and clarifications.
We look forward to hear from you.
Should there be no response, we will follow up after 3 business days.
Crisselle C
Caguicla_Intel
Hello SSass3,
Good day!
Please let us know if you were able to submit a request on the provided link above. In case yo have additional questions, please do not hesitate to ask.
Awaiting to your reply.
We will follow up after 3 business days should there be no response from you.
Crisselle C
SSass3
Thanks a lot, We found a workaround that uses the same clock on the x710 by using 2 different VLANs
Caguicla_Intel
Hello SSass3,
Thank you for the update.
We are glad to hear that there is a workaround for this query. Please be informed that we will now close this request. Just feel free to post a new question if you may have any other inquiry in the future.
May you have an amazing day ahead!
Crisselle C
