Ethernet Products
5744 Discussions
Pci-pasthrough and SRIOV on the same host
BDemi3
Can i use PCI-Passthru and SRIOV on the same hosts for different ports? ens1f0-1 SRIOV with multiple VFs and ens2f0-1 pci-passthru ?
I have 2 apps on the same hosts one supports SRIOV and the other one only supports pci-passthru.
thanks,
BDemi3
Correction: Cannot create a VM with 1-port VF and another PF. So same host can have PF and VF but same VM?
Hi Demirel,
Thank you for the post. Can you share what is the exact network adapter? The exact OS used?
rgds,
wb
BDemi3
RHEL 7.3 and 82599ES
I believe this is supported.
Hi Demirel,
Thank you for the information. I will have to check on this.
rgds,
wb
Hi Demirel,
If you have two network controller, each should be function separately without dependency, in case there is restriction please check on the host level, you can double chck with Redhat* support for similar implementation.
Can you share more specific information regarding the application
you use for passthrough and the application for SR-IOV.
Please elaborate also regarding "Cannot create a VM with 1-port VF and another PF. So same host can have PF and VF but same VM"
What is the application used for creating VM? What is the error message?
wb
BDemi3
Double checked this with RH, it is possible. We were using a an application from Sandvine for traffic steering. It was a misconfig
thanks for the answer
Hi Demirel,
Thank you for the update.
Rgds,
wb
