Ethernet Products
5821 Discussions
Voltage levels are not as per the specs of I210
We are using Intel's Atom processor with Springville I210 controller as Ethernet PHY.
The PCIe port of Atom processor is connected to Springville to convert PCIe into MDI signals which are then connected to an Ethernet PHY switch.
We are using this link at a speed of 100Mbps.
Concern here is that, the voltage levels of MDI signals which are coming out from Springville is around 5V pk-pk. This is not as per the standard specs of MDI signals.
Can any one please suggest if any settings has to made to correct this,
Pradyumna
Hi Pradyumna,
Thank you for posting in Wired Ethernet Communities.
I'm currently checking your query and will update this thread as soon as possible.
regards,
Vince
Hi Pradyumna,
Given your concern involves design, I'd suggest to post your question in our embedded community for assistance.
https://embedded.communities.intel.com/community/en
regards,
Vince
Hi Pradyumna,
You may also consider applying for privilege access in our Research and Design center, kindly refer to the link below:
http://www.intel.com/content/www/us/en/design/support/account-support.html .
Once approved, This will allow access to Intel confidential content, pre-release information on upcoming products, advanced design tools, and support services to help with your design.
regards,
Vince
