Ethernet Products
5671 Discussions
Poor performance on X722 10 Gb interface
AWilh1
Hi. I have a Lenovo SR650, with Intel X722 10 Gb interfaces. Used as backup server.
I have configured teamin using the windows feature in 2012 R2 version. I have also configured teaming interfaces (with VLAN), because i need this server to have direct connections in different network segments. The thing is that i get poor performance when the client send the data to the backup server. I have 20 Gb infrastructure and the clients send data with no more then 800 Mb/s. I have deactivated TCP checksum offload and got a little better performance. But does not help that much. Deactivating other features did not help.
Has anyone experienced such issues?
Is there a software form Intel that could be used in order to create the teaming on windows 2012 R2?
Best regards!
Hello Alexia-net,
Thank you for posting in Intel Wired Ethernet Communities. Please post the logs from the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- System Support Utility to give us a better idea of the drivers and teaming/VLAN configurations on your server and client systems. The https://www.intel.com/content/www/us/en/support/articles/000008490/software/software-applications.html FAQs have additional information about this utility.
  • Download and run the .exe from the link above
  • Check "everything" then click "scan"
  • When scan is finished click "next"
  • Save the log and attach it to a post
https://downloadcenter.intel.com/download/23073/Ethernet-Intel-Network-Adapter-Driver-for-Windows-Server-2012-R2- Advanced network services can be used to create teams/VLANs from the device properties in device manager. What are the client and server connecting to?
If you have any questions please do not hesitate to contact us.
Daniel D
Hello Alexia-net,
Please let us know if you still need assistance with this issue. If installing Advanced network services has helped you with the issue, or If you are having difficulty providing the SSU information please inform us.
Daniel D
Hello Alexia-net,
Please let us know if you still have any questions regarding this issue.
Daniel D
Intel Customer Support
