Ethernet Products
公告
5864 讨论
Pre-boot DMA Protection issue with Intel X610-XT2 NIC
noarch
初学者
448 次查看
I'm using drivers 1.7.44.0 from 2026-02-18 on a Dell Optiplex 7020 and it seems the X610 NIC has issues with Pre-Boot-DMA Protection, as it looses connectivity during boot time.
Disabling said DMA Protection resolves the issue, but I'd like to keep this option on.
Is this the expected behavior?
0 项奖励
11 回复数
Dineshbabu
员工
435 次查看
Hello noarch,
Greetings!
Thank you for posting in the Intel Community. We acknowledge receipt of your concern and would like to assure you that assisting you is our top priority. To effectively troubleshoot the issue you're facing, we require some additional information from your end.
  • Kindly reconfirm the adapter model.
  • Could you please confirm whether the driver used is from Intel or Dell?
  • Could you please confirm whether the adapter was purchased separately or pre-installed on the system?
  • Please confirm whether this behavior was observed after a driver update.
Dinesh
0 项奖励
noarch
初学者
418 次查看
Hi Dineshbabu,
this is a PCIe networking card "Intel® Ethernet Network Adapter E610-XT2"[1] which I added to my Dell Optiplex by myself.
The driver in use is Intel(R) Network Connections Software, Release 31.1 for Windows 11 from 2026-03-01, the driver version and date given above was displayed in my computer management.
Since 31.1 is the latest Intel driver I tried downgrading, but that didn't seem to have any effect.
__
[1] https://www.intel.de/content/www/de/de/products/sku/237052/intel-ethernet-network-adapter-e610xt2/specifications.html
0 项奖励
MACM
员工
417 次查看
Hello Noarch,
Greetings!
Thank you for your response.
Could you please provide us the error screenshots and error messages.
So that we can validate and proceed further accordingly.
Mohammed Ali CM
0 项奖励
noarch
初学者
366 次查看
Nothing noteworthy, ixw logs with error 27:
Intel(R) Ethernet Network Adapter E610-XT2
The network connection has been lost.
Multiple GPOs throw errors for not beeing able to be applied.
And broken network shares, but this is all expected, if the NIC loses connection during boot-up as initially stated.
So is this expected behavior of this hardware? Is Pre-Boot DMA protection not supported by the
0 项奖励
Dineshbabu
员工
363 次查看
Hi Noarch,
Greetings!
Thank you for your response. Please allow us some time to review the details and we will get back with an update shortly.
Dinesh
0 项奖励
Sazirah
员工
351 次查看
Hi noarch,
Greetings.
Regarding this issue, we require additional information from your end:
i) Could you please confirm whether you are attempting a PXE/network boot, or any other pre‑boot or early‑boot network activity, at the time when you see the connectivity loss? Please give us more details.
ii) Kindly share clear pictures of the Ethernet card (showing the full adapter and label)
iii) Please share the NVM firmware version of the adapter (can be collected via SSU logs, you may refer link below on how to generate the SSU log)
https://www.intel.com/content/www/us/en/support/articles/000008563/ethernet-products.html
https://www.intel.com/content/www/us/en/download/18895/intel-system-support-utility-for-the-linux-operating-system.html
We look forward for your response regarding this.
Sazzy_Intel
0 项奖励
Dineshbabu
员工
214 次查看
Hello noarch,
Greetings for the day!
We are following up to find out if you were able to find the information we provided. Please reply to confirm, so we can continue helping on a resolution. Looking forward to receiving your reply.
Dinesh
0 项奖励
noarch
初学者
207 次查看
Hi Sazira,
hi Dineshabu,
sorry for the delay, here are the requested informations:
i) I just boot from my local dreive, no network boot or uefi-networking activity is present.
ii) See attached image.
iii) NVM Version Not Available
0 项奖励
pujeeth
员工
202 次查看
Hello noarch,
Greeting!
Thank you for sharing the information, We would request you to share us the SSU logs for further analysis.
Pujeeth_Intel
0 项奖励
noarch
初学者
198 次查看
I'd rather not post identifiable information in public.
Here is a cropped version.
0 项奖励
Sreelakshmi1
员工
193 次查看
Hi noarch,
Thank you for your response. We have shared an email requesting a few details. Kindly provide the information at your convenience.
Sreelakshmi
0 项奖励
回复
