Ethernet Products
5703 Discussions
Problem z aktualizacja Intel(R) Ethernet Controller (3) I225-V
axs1
Próbuje zaktualizować jak i automatycznego wyszukiwania przez Windows jak i manualnie. Pobierałem najnowsze sterowniki z strony Intel plik: wired_driver_30.3. Mimo wszelakich prób wersja sterownika zostaje cały czas taka sama czyli 2.1.4.3 z 2024 roku. Bardzo prosiłbym o pomoc ,ponieważ moja prędkość przesyła jest capped na 100mb/s mimo kabla zdolnego przesłu 2.5gb/s jak i portu itp..Tak samo mój dostawca orange światłowód nie jest powodem tego problemu.
LeonWaksman
Witam @axs1
Pomoc tutaj jest udzielana tylko w języku angielskim:
In order to get better information about your system, please download the Intel System Support Utility (SSU). Run the SSU scan (check "Everything") and save the results. The .txt file with the results please attach to your post.
Leon
axs1
I'm trying to update both through Windows' automatic search and manually. I've downloaded the latest drivers from the Intel website: wired_driver_30.3. Despite all attempts, the driver version remains the same, 2.1.4.3, released in 2024. I'd appreciate any help, as my transfer speed is capped at 100 Mbps despite a cable capable of 2.5 Gbps, a port, etc. My Orange provider isn't the cause of this problem either.
Sazirah
Hi axs1,
Thank you for posting in Intel Community Forum.
Regarding your driver update issue, do you encounter any error message when updating it? If yes, kindly help to share the screenshot of the error. Also, may I know the operating system that you are currently using?
To isolate the issue further, kindly follow steps below:
-Do clean driver installation. Please refer link below:
https://www.intel.com/content/www/us/en/support/articles/000058304/ethernet-products.html
-Please proceed with install the latest ethernet driver (version 30.4) as per link below:
https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html
Once complete, let us know the outcome.
Sazzy_Intel
Sazirah
Hi axs1,
Greetings.
I would like to follow up with you regarding this case. If you require any assistance from my end regarding this case, kindly let me know.
Sazzy_Intel
Sazirah
Hi axs1,
Good day
This is regarding your enquiries above. Since we have not seen an update, if you need any additional information, please submit a new question as this thread will no longer be monitored.
Sazzy_Intel
