Ethernet Products
5776 Discussions
RSS Support in IXGBEVF
MTang5
I am using 3.3.2 ixgbevf in guest and 5.0.4 ixgbe on host. I noticed that even though there are two RX queues for each VF, but pretty much all the packets go to the first RX queue. The RSS related features are also not supported. How to turn on the RSS support on ixgbevf? If it does not support RSS, what's the point having multiple queues in ixgbevf?
root@ubuntu14:~# ethtool -n eth1
2 RX rings available
rxclass: Cannot get RX class rule count: Operation not supported
RX classification rule retrieval failed
root@ubuntu14:~# ethtool -x eth1
Cannot get RX flow hash indirection table: Operation not permitted
root@ubuntu14:~# ethtool -g eth1
Ring parameters for eth1:
Pre-set maximums:
RX: 4096
RX Mini: 0
RX Jumbo: 0
TX: 4096
Current hardware settings:
RX: 512
RX Mini: 0
RX Jumbo: 0
TX: 1024
root@ubuntu14:~# ethtool -k eth1
Features for eth1:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: on
tx-checksum-ip-generic: off [fixed]
tx-checksum-ipv6: on
tx-checksum-fcoe-crc: off [fixed]
tx-checksum-sctp: off [fixed]
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: off [fixed]
tx-tcp6-segmentation: on
udp-fragmentation-offload: off [fixed]
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off [fixed]
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: off [fixed]
receive-hashing: off [fixed]
highdma: on [fixed]
rx-vlan-filter: on
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: off [fixed]
tx-ipip-segmentation: off [fixed]
tx-sit-segmentation: off [fixed]
tx-udp_tnl-segmentation: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off [fixed]
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
l2-fwd-offload: off [fixed]
busy-poll: on [fixed]
Hi Mintang,
Thank you for posting at Wired Communities. Please share what is the exact model of your network adapter and what is the system board(brand and model).
thanks,
wb
MTang5
Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01).
Hi Mintang,
Thank you for the information. Is this an onboard NIC? and what is the brand and model of your server?
wb
Hi Mintang,
RSS is not supported on ixgbevf driver as ixgbevf driver is intended for virtual operating system. RSS is used on host operating system
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000006703.html
. If you want to have multiple queue in ixgbevf (this is driver for virtual function) you can use vmdq features, please refer to this website for reference:
https://www.intel.com/content/www/us/en/ethernet-products/converged-network-adapters/io-acceleration-technology-vmdq.html
It is recommended to check with Ubuntu if vmdq is supported.
wb
MTang5
VMDQ is not an option for us because we have to do SR-IOV. According to thehttp://dpdk.org/doc/guides/nics/intel_vf.html DPDK document, RSS is supported in VF but it has to set on host:
"On host, to enable VF RSS functionality, rx mq mode should be set as ETH_MQ_RX_VMDQ_RSS or ETH_MQ_RX_RSS mode, and SRIOV mode should be activated (max_vfs >= 1). It also needs config VF RSS information like hash function, RSS key, RSS key length."
"Note
The limitation for VF RSS on Intel® 82599 10 Gigabit Ethernet Controller is: The hash and key are shared among PF and all VF, the RETA table with 128 entries is also shared among PF and all VF; So it could not to provide a method to query the hash and reta content per VF on guest, while, if possible, please query them on host for the shared RETA information."
It is for the DPDK driver, but not the regular linux kernel driver. It looks to me that hardware supports it, just the linux kernel driver on host does not expose the interface to do it.
Hi Mintang,
Thank you for the clarification. Are you using the DPDK? If yes, then all Intel® DPDK questions and technical problems including those regarding the Ethernet* Controllers for the Poll Mode Driver should be reported through the Intel® Premier Support site
http://premier.intel.com/premier http://premier.intel.com/premier or access your IBL account and click
the Intel® Premier Support link to enter issues under the Product Name
"Data Plane Development Kit (DPDK)", which are then routed to our support team
wb
MTang5
I am not using DPDK. I just used the DPDK doc to show that RSS is supported on VF. Actually the http://elixir.free-electrons.com/linux/v4.1/source/drivers/net/ethernet/intel/ixgbe/ixgbe_sriov.c# L109 ixgbe driver in the linux kernel also suggests that RSS is supported on VF. For 82599, the indirection table and RSS hash key cannot be changed on VF, but RSS should work on VF.
for (i = 0; i < adapter->num_vfs; i++) {
/* enable spoof checking for all VFs */
adapter->vfinfo[i].spoofchk_enabled = true;
/* We support VF RSS querying only for 82599 and x540
* devices at the moment. These devices share RSS
* indirection table and RSS hash key with PF therefore
* we want to disable the querying by default.
adapter->vfinfo[i].rss_query_enabled = 0;
Hi Mintang,
regards,
wb
Hi Mintang,
Further checking, please use DPDK option to configure.
sharon
