Ethernet Products
5520 Discussions
Re: Intel 82579V drops connection every hour on windows 10
PSche4
I encountered the same Problem.
Additional Information:
before 23.07.17 the system worked properly with windows 10 64 home.
in the eventlog of the Adapter i can find an update from 23.07.17 22:23.
Since this update windows presents after system start an Intel 82579LM insted of Intel 82579V in the device manger.
A klick on the recongnize changed hardware button solves the Problem for some time, (I didn't test if it reoccures after longer work, e.g. one hour)
But always after a system reboot or cold boot the same problem occures again.
The latest driver is installed,
Cable an router checked.
Any suggestions?
Hi Pscheeder,
Thank you for posting at Wired Communities. What is the brand and model of your system?
You may try updating the firmware of the 82579V to rectify the issue that 82574v was detected as 82579LM, please refer to below website for the update:
https://downloadcenter.intel.com/download/22026/NVM-Update-Utility-for-Intel-82579V-Gigabit-Ethernet-PHY-Network-Connection?product=47549
regards,
sharon
Hi Pscheeder,
regards,
sharon
Hi Pscheeder,
Please feel free to update me if the issue is fixed.
sharon
