Ethernet Products
4907 Discussions
Re: igb Detected Tx Unit Hang
SLee117
Hi Experts,
i am facing similar issue with I350 4 ports
kernel: [ 918.176288] igb 0000:03:00.3: Detected Tx Unit Hang
kernel: [ 918.176289] Tx Queue <3>
kernel: [ 918.176290] TDH <59>
kernel: [ 918.176291] TDT <5a>
kernel: [ 918.176292] next_to_use <5a>
kernel: [ 918.176293] next_to_clean <59>
kernel: [ 918.176294] buffer_info[next_to_clean]
kernel: [ 918.176295] time_stamp <1000953e4>
kernel: [ 918.176296] next_to_watch
kernel: [ 918.176297] jiffies <100096ce1>
kernel: [ 918.176298] desc.status <148000>
kernel: [ 919.172375] ------------[ cut here ]------------
Kernel 2.6.34.15
driver: igb
version: 5.3.0
firmware-version: 1.61, 0x8000091f
Any suggestion?
Sam
Hi Sam,
Thank you for the post. Just to double check if you are using the driver from this site?
https://downloadcenter.intel.com/download/13663/Intel-Network-Adapter-Driver-for-82575-6-82580-I350-and-I210-211-Based-Gigabit-Network-Connections-for-Linux-
wb
SLee117
Hi Wb,
Good day.
No, i am not using this driver https://downloadcenter.intel.com/downloads/eula/13663/Intel-Network-Adapter-Driver-for-82575-6-82580-I350-and-I210-211-Based-Gigabit-Network-Connections-for-Linux-?httpDown=https://downloadmirror.intel.com/13663/eng/igb-5.3.5.4.tar.gz Intel® Network Adapter Driver for 82575/6, 82580, I350, and I210/211-Based Gigabit Network Connections for Linux*
i am using the igb driver 5.3.0
here is my output for ethtool
# ethtool -i front_sfp0
driver: igb
version: 5.3.0
bus-info: 0000:03:00.3
Sam
Hi Sam,
Thank you for the reply. Where did you obtain the 5.3.0 driver? any chance you can try the driver on our website? Just to double check if your I350 is an onboard NIC or standalone network adapter that can be plugged in and pulled out? If it is an onboard NIC what is the brand and model of your system?
wb
Hi Sam,
By the way, I sent a PM to you.
rgds,
wb
HI Sam,
Please feel free to provide the information.
Rdgs,
wb
SLee117
Hi Wb,
Good day.
Please refer to the replies below.
HW:
We are using onboard I350
lspci -s 03:00.3 -n -v
03:00.3 0200: 8086:1522 (rev 01)
Subsystem: 1223:0055
Flags: bus master, fast devsel, latency 0, IRQ 29
Memory at d1b00000 (32-bit, non-prefetchable) [size=128K]
I/O ports at 5000 [size=32]
Memory at d1bc0000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [70] MSI-X: Enable+ Count=10 Masked-
Capabilities: [a0] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Device Serial Number ec-9e-cd-ff-ff-04-1e-76
Capabilities: [150] Alternative Routing-ID Interpretation (ARI)
Capabilities: [160] Single Root I/O Virtualization (SR-IOV)
Capabilities: [1a0] # 17
Capabilities: [1d0] Access Control Services
Kernel driver in use: igb
SW:
We are using Wind River Linux (2.6.34.15-WR4.3.x86_64) and the driver comes from Wind River. As i know , Wind River is also a company of Intel.
Sam
Hi Sam,
Thank you for the information. Please try contacting Wind River support as you are using Wind River driver and OS. Feel free to update us. Thank you.
rgds,
wb
Hi Sam,
Please feel free to update if you have contacted Wind River support and if there are other inquiries. Thanks.
wb
