Ethernet Products
5530 Discussions
Should XXV710 aggregate inter-VF throughput be limited to 25Gbps or VEB/PCI bandwidth
User1575447903964661
I have a XXV710-DA2 on a host. On which I am running multiple VMs with SRIOV. I am assigning two VFs from the same port, to two differnt VMs. The VMs are using DPDK.
I was hoping that the inter-VM/VF throughput would be switched in the VEB and thus would be far greater than 25Gbps (upto PCI bandwidth).
But the total throughput (across all VMs) is limited to 25Gbps aggregate. For e.g. I can only do 12.5Gbps bi-directional throughput between two VMs. So VM1 can only TX 12.5 (which is RX for VM2) and RX 12.5 (which is TX from VM1). If I move one VM to another host, they can do 25 Gbps bi-dir, no issue.
I have enabled loopback on all the VF interfaces, on the host
# cat /sys/class/net/p3p2/device/sriov/3/loopback
on
# cat /sys/class/net/p3p2/device/sriov/2/loopback
on
Firmware version is 7.0
Am I missing something?
Pratik
AlfredoS_Intel
Hello User15754479039646610788,
Thank you for patiently waiting for our update.
Please check on figure 15 of the document that you referenced; there is a note there that states “All numbers used for the KPIs are on the Transmit side of the VNF VM only”. That shows that each of the 8 VMs on a 40Gb interface is getting a 4.55Gb transmit speed, which combines to 36.45Gb; due to that reason, it is normal if you are getting 12.5 Gb of transmit on each of the 2 VMs. If you increase it to 5 VMs, then it would be 5Gb for each.
Additionally, if you put 1 VF on each port, then you may get closer to the 25Gb per VM; however, there may be additional overhead for the communication between the two ports.
Alfred S
Intel® Customer Support
A Contingent Worker at Intel
Mike_Intel
Regarding your inquiry about DPDK, we have a different team who supports DPDK.
Please open the link below to log your inquiry.
https://www.intel.com/content/www/us/en/design/support/ips/training/welcome.html
Click the "Login and Access" to contact the DPDK support
If you have questions, please let us know.
Michael L.
Intel Customer Support Technicians
Thank you for the response.
When I try to use the link, it says "You don't have Access to IPS. Please contact the FAE to get access."
Nevertheless, my question is not about DPDK. Lets assume that I am using normal kernel driver inside the VM. My question is about whether VF-VF throughput should be limited by the port capacity. As per the link below, that should not be the case. But I am seeing that it is.
https://www.intel.com/content/dam/www/public/us/en/documents/technology-briefs/sr-iov-nfv-tech-brief.pdf
Mike_Intel
If you are having login or access issue, please try to contact their support below:
https://www.intel.com/content/www/us/en/design/support/ips/training/access-and-login.html
You may also try to email the support on this email address: smg.customer.support@intel.com
And also, for me to further check. Kindly provide the following details.
  1. What is the model of your system?
  2. Are you using an on-board Ethernet card?
  3. Can you also show us any data about your inquiry?
Michael L.
Thank you for the followup.
1. My system is Intel(R) Xeon(R) Gold 6126 CPU @ 2.60GHz, running CentOS7
2. XXV710 is in a x8 PCI slot.
 lspci -s d8:00.0 -vvv | grep LnkSt
LnkSta: Speed 8GT/s, Width x8, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
3. As I indicated above, the VMs are using SRIOV. When VM1 data leaves the NIC port, (say to VM2 on another host), I see 25 Gbps full duplex (50 Gbps IO). But when I move VM2 to the same host, my throughput falls to 12.5 Gbps. My basic question is that do I need to do something special to turn on NIC based VF switching (VEB)? The host has enough compute capacity.
Pratik
Mike_Intel
Thank you for providing the information that I requested. I need to further check if there is a settings for that.
Please give me 2 to 3 days to provide an update.
Michael L.
Mike_Intel
Upon further checking  if you are using SR-IOV, the inter-VF throughput is limited to 25Gbps, you may explore the implementation of DPDK Vhost for higher throughput.
For DPDK resources, please refer to the following sites for details and assistance:
https://doc.dpdk.org/guides/sample_app_ug/vhost.html
software forum - https://software.intel.com/en-us/forums/networking
Michael L.
Thank you for the info.
Can I request you to pl. double check? Because it does not seem to be aligned to the following white paper:
which says that inter-VF 2 VM throughput to exceed line rate for XL710 (page 40, SRIOV east-west 2VM is 44.44 Gbps). And the document says that this would be limited by PCI BW and NIC packet processing capacity. I don't think either applies to me w/ 2 VMs.
Thanks again
AlfredoS_Intel
Please allow us some time to re-check this. Please give us 2 to 3 days to provide you with an update.
Alfred S
AlfredoS_Intel
Alfred S
Mike_Intel
I just want to check if you still have questions, or clarifications. Please let us know.
Michael L.
Mike_Intel
I am just sending another follow up if you still have questions or clarifications.
Since we have not heard back from you, I will close this inquiry now.
If you need further assistance, please post a new question.
Michael L.
Thank you for your response. I am all set.
