Ethernet Products
5661 Discussions
TX driver issue detected, PF reset issued
doordie
Hi, guys:
      We encountered a PF reset issue at production environtment.  The messages (Debian Linux) is like as below:
The driver/Nvm is like this 6.01/2.4.10:
According to intel, it is supposed to work well. But we have no luck.
Then we try to upgrade the driver to 2.14.13.
After running roughly one day, we got the error below.
Why did this happen?!
Any help or clue will be appreciated! Thank you.
Best wishes.
Irwan_Intel
Hi doordie,
In order for us to further investigate the issue, we would like addtional info such as below:
1) What is your system model and Debian version, kernel version?
2) Can you provide us more details of the NIC card model, please provide picture of the NIC card focusing on the markings on board.
The latest Intel generic firmware is V9.20 and the driver version 2.22.18. Have you try updating the drivers and firmware and see if the issues persist.
https://www.intel.com/content/www/us/en/products/details/ethernet/700-network-adapters/x710-network-adapters/downloads.html
Notes: From your screenshot, NVM i40e (Linux)*1
*1 = These are out-of-tree versions.
Irwan_Intel
doordie
Hi Irwan_intel:
       Thank you for your reply.
      1),  We use brctl to create a virtual bridge consisting of two x710 ports to forward packets(No lacp).  It's Debian 10.6 with kernel 4.20.1.
      2),  The Nic is this: "Ethernet Converged Network Adapter X710"
https://pci-ids.ucw.cz/read/PC/8086/1572
I tried the latest driver (2.22.18),but it's not supported by the kernel. See below:
Again, NVM/driver: 6.01/2.14.13.  Here is some the messages.
I'm not sure if the mismatch of nvm&driver will still cause the up/down issue. Perhaps I should give it a try later.
Waiting for your reply.
Thank you.
Irwan_Intel
Hi doordie,
According to our next level, I40e driver doesn't support Debian 10, and it's possible that the newest driver may not work as expected.
However, we suggest that you use the in-kernel Debian driver instead.
We also noticed that the NVM version you are currently using is quite old. Have you tried updating the NVM to see if that makes a difference? An updated NVM version can often resolve compatibility issues with newer drivers.
https://www.intel.com/content/www/us/en/download/18190/non-volatile-memory-nvm-update-utility-for-intel-ethernet-network-adapter-700-series.html
Please let us know if updating the NVM helps resolve your issue or if you have any further questions or concerns.
Irwan_Intel
doordie
Hi Irwan_Intel,
         Thanks a lot for your help. Last night we updated the NVM and everything looks fine until now. But what worries me is that the root cause of all the issues.
         First of all,  the nvm/driver should match each other according to the table  offered by intel. It is not easy for me to know if it's a chip bug or not.  Do you guys have methods to help us deal with these problems?  Any analysing tools?   At the very begining, we changed the wire and sfp modules.
         BTW, there is anything new, we will let you know.
 Thank you.
  doordie.
Irwan_Intel
Hi doordie,
We're glad to hear that updating the NVM helped resolve the issues you were experiencing.
However, we understand your concern about the NVM/driver compatibility in the list.
I will check with our next level to see if there is any method or tools that can help to rectify the issue.
Also, we appreciate your updates and please don't hesitate to reach out to us if anything changes.
Irwan_Intel
doordie
Hi, Irwan_intel:
       Bad news!    The port  went down again.
     I'm working on it!
     Thank you.
Irwan_Intel
Hi doordie,
I'm sorry to hear that the port went down again. Can you provide some more information about the situation? Have you tried any troubleshooting steps?
Look forward to your reply.
Irwan_Intel
doordie
Hi, Irwan_Intel:
                    Thank you for asking. Actually we don't have any clue. But I did below on 21, April.
                /sbin/ethtool -K ens1f0 tso off gro off gso off
                /sbin/ethtool -K ens1f1 tso off gro off gso off
                /sbin/ethtool -G ens1f0 rx 4096 tx 4096
                /sbin/ethtool -G ens1f1 rx 4096 tx 4096
                     Don't know exactly the root cause, just try it. Everything is fine since then, we'll let you know if there is anythin new.
         Regards.
         doordie
Irwan_Intel
Hi doordie,
I hope this message finds you well. I wanted to follow up with you regarding this issue. I wanted to see if there have been any updates or if there is anything I can assist with.
Please let me know if there is anything I can do to help or if you have any new information to share. Thank you and have a great day!
Irwan_Intel
Irwan_Intel
Dear doordie,
Regarding your issue, I would like to inform you that I have reviewed your issue and it seems that the matter has been resolved.
If you have any further questions or concerns, please don't hesitate to reach out to me. Otherwise, I will be closing this ticket now.
Thank you for your time and have a great day!
Irwan_Intel
