Ethernet Products
5868 Discussions
Tofino 3 Details/Match-Action Table Clarification
ThePuriProdigy
Hi all, a common way I see pipeline architectures in devices such as the Tofino 3 switch that contain MAU units defined is each MAU has x TCAM blocks and y SRAM pages. Are the x and y amounts of TCAM/SRAM referring to the amount available solely for the key portion of a key, action, action data table? As an example, if an MAU is described as having 100 SRAM pages available and my algorithm will use 100 SRAM pages worth of keys + additional 20 pages for the action data, is that fine? Or will the action data SRAM amount also need to be factored in so that the key+action data will not exceed 100 pages total?
Also, I was wondering if there was a way to find out specific Tofino 3 specs such as the number of MAUs per pipeline and the amount of TCAM blocks/SRAM pages that they each hold?
Mike_Intel
Hello ThePuriProdigy,
For us to further check the issue, please provide the following details.
  1. What is the model of the Intel network card that you are using?
  2. Can you share screen capture of the issue?
  3. Are you designing a board/system with embedded Intel NIC?
  4. Can you share more details about your inquiry?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel® Customer Support
Mike_Intel
I hope you're having a wonderful day. I am just sending a soft follow up on the information that we requested for us to further assist you. We will wait for your reply.
Michael L.
Mike_Intel
I hope this message finds you well. I am just sending another follow up on the information that I requested. Since we have not heard back from you, I need to close this inquiry.
Thank you and stay safe.
Michael L.
