Ethernet Products
5861 Discussions
Unable to obtain IP address on Intel I219-V on EFI
gomidas95
I am working on a simple system that establishes an internet connection before ExitBootServices by using the driver version of iPXE. In addition to this, I use BearSSL to provide HTTPS support. This setup works reliably as long as Boot Services are active.
However, once ExitBootServices is called, these drivers become unavailable (no SNP), and I need to manage everything myself.
I am using an Intel I219-V network card, and I have been trying to prepare a compatible implementation here: https://spitakgames.com/gnu-efi
When I debug the GNU-EFI project, it attempts to obtain an IP address at startup, but it fails and cannot acquire one. I haven’t been able to determine where the issue is.
HERE IS HTTPS CONNECTION WITH SNP (WORKS):  - YouTube
HERE IS OUTPUT OF PROBLEM (NO SNP):  - YouTube
SCREENSHOT:
Could you help me figure out what might be going wrong?
pujeeth
Hello gomidas95,
Thank you for contacting Intel.
To proceed further with troubleshooting, we kindly request you to provide the following information:
1.Please share the SSU logs using the following link:
https://www.intel.com/content/www/us/en/support/articles/000008563/ethernet-products.html
2.Kindly confirm whether your concern is related to the built-in network controller on the motherboard or a separately purchased PCIe network adapter.
Pujeeth_Intel
gomidas95
SSU:
# SSU Scan Information
Scan Info:
Version:"4.3.2.0"
Date:"04.30.2026"
Time:"00:00:01.8367580"
# Scanned Hardware
Computer:
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"Not Available"
- "Hyper-V Virtual Ethernet Adapter"
Caption:"Hyper-V Virtual Ethernet Adapter"
CoInstallers:"Not Available"
Default IP Gateway:"Not Available"
DHCP Enabled:"No"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"VmsProxyHNic.sys"
Driver Date:"06.21.2006 12:00 ÖÖ"
Driver Path:"C:\Windows\system32\drivers\VmsProxyHNic.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.19041.1"
Index:"0013"
INF:"wvms_mp_windows.inf"
INF Section:"VMSMP.ndi"
Install Date:"Not Available"
Installed:"Yes"
IP Address:"172.23.16.1;fe80::246f:6837:91c6:293d"
IP Subnet:"255.255.240.0;64"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"04.30.2026 08:12 ÖS"
MAC Address:"00:15:**:**:**:**"
Manufacturer:"Microsoft"
Media Type:
Net Connection ID:"vEthernet (Ethernet)"
NetCfgInstanceId:"{F3154460-95D4-453E-A5BF-AA6BD8CC2331}"
Number of VLANs:"0"
PNP Device ID:"ROOT\VMS_MP\0000"
Port:"Not Available"
Power Management (Low Power):"Not Available"
Power Management (Wake On LAN):"Not Available"
Power Management (Wake on Magic Packet):"Not Available"
Power Management Capabilities:"Not Available"
Power Management Supported:"No"
Product Type:"Hyper-V Virtual Ethernet Adapter"
Service Name:"VMSNPXYMP"
Status:"Enabled"
Team Name:"Not in a team"
Temperature:
Type:"Ethernet 802.3"
- "Service Bindings"
Bağlantı Katmanı Topolojisi Bulma Eşleyicisi G/Ç Sürücüsü:
Bağlantı Katmanı Topolojisi Bulma Yanıtlayıcısı:
İnternet Protokolü Sürüm 4 (TCP/IPv4):
İnternet Protokolü Sürüm 6 (TCP/IPv6):
Köprü Sürücüsü:
Microsoft Ağları için Dosya ve Yazıcı Paylaşımı:
Microsoft Ağları için İstemci:
Microsoft LLDP Protokolü Sürücüsü:
Microsoft Network Monitor 3 Driver:
Npcap Packet Driver (NPCAP):
QoS Paket Zamanlayıcısı:
- "Settings"
*IPChecksumOffloadIPv4:IPv4 Checksum Offload:"Rx & Tx Enabled (3)"
*IPsecOffloadV2:IPSec Offload:"Auth Header and ESP Enabled (3)"
*JumboPacket:Jumbo Packet:"Disabled (1514)"
*LsoV2IPv4:Large Send Offload Version 2 (IPv4):"Enabled (1)"
*LsoV2IPv6:Large Send Offload Version 2 (IPv6):"Enabled (1)"
*MaxRssProcessors:Maximum Number of RSS Processors:"8 (8)"
*NetworkDirect:Network Direct (RDMA):"Disabled (0)"
*NumRSSQueues:Maximum Number of RSS Queues:"8 (8)"
*RscIPv4:Recv Segment Coalescing (IPv4):"Enabled (1)"
*RscIPv6:Recv Segment Coalescing (IPv6):"Enabled (1)"
*RSS:Receive Side Scaling:"Enabled (1)"
*RssBaseProcNumber:RSS Base Processor Number:"0 (0)"
*RssMaxProcNumber:Maximum RSS Processor Number:"63 (63)"
*RSSProfile:RSS Profile:"Closest Processor Static (2)"
*TCPChecksumOffloadIPv4:TCP Checksum Offload (IPv4):"Rx & Tx Enabled (3)"
*TCPChecksumOffloadIPv6:TCP Checksum Offload (IPv6):"Rx & Tx Enabled (3)"
*UDPChecksumOffloadIPv4:UDP Checksum Offload (IPv4):"Rx & Tx Enabled (3)"
*UDPChecksumOffloadIPv6:UDP Checksum Offload (IPv6):"Rx & Tx Enabled (3)"
- "Intel(R) Ethernet Connection (2) I219-V"
- "Caption":"Intel(R) Ethernet Connection (2) I219-V"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Ethernet+Connection+(2)+I219+V"
Default IP Gateway:"192.168.0.1"
DHCP Enabled:"Yes"
DHCP Lease Expires:"05.07.2026 08:12 ÖS"
DHCP Lease Obtained:"04.30.2026 08:12 ÖS"
DHCP Server:"192.168.0.1"
Driver:"e1d68x64.sys"
Driver Date:"06.22.2021 12:00 ÖÖ"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\e1d68x64.inf_amd64_b32d0891eb98aee4\e1d68x64.sys"
Driver Provider:"Intel"
Driver Version:"12.19.1.37"
ETrackID:"Not Available"
Index:"0009"
INF:"oem118.inf"
INF Section:"E15B8.10.0.1.19H1"
Installed:"Yes"
IP Address:"192.168.0.13;fe80::eaa6:b169:f7c3:ba5f"
IP Subnet:"255.255.255.0;64"
MAC Address:"00:1F:**:**:**:**"
Manufacturer:"Intel"
Media Type:
Net Connection ID:"Ethernet"
NetCfgInstanceId:"{3F7C9CFB-9E1A-4D7A-BE6C-1D383B4B307F}"
Number of VLANs:"0"
NVM Version:"Not Available"
Part Number:"FFFFFF-0FF"
PNP Device ID:"PCI\VEN_8086&DEV_15B8&SUBSYS_00008086&REV_00\*&11******&0&**"
Power Management (Low Power):"Active: Yes, Enable: Yes"
Power Management (Wake On LAN):"Active: Yes, Enable: Yes"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Product Type:"Intel(R) Ethernet Connection (2) I219-V"
Service Name:"e1dexpress"
Status:"Enabled"
Temperature:
Köprü Sürücüsü:
- "Settings"
*FlowControl:Flow Control:"Rx & Tx Enabled (3)"
*InterruptModeration:Interrupt Moderation:"Enabled (1)"
*LsoV2IPv4:Large Send Offload V2 (IPv4):"Enabled (1)"
*LsoV2IPv6:Large Send Offload V2 (IPv6):"Enabled (1)"
*NumRssQueues:Maximum Number of RSS Queues:"2 Queues (2)"
*PMARPOffload:Protocol ARP Offload:"Enabled (1)"
*PMNSOffload:Protocol NS Offload:"Enabled (1)"
*PriorityVLANTag:Packet Priority & VLAN:"Packet Priority & VLAN Enabled (3)"
*PtpHardwareTimestamp:PTP Hardware Timestamp:"Disabled (0)"
*ReceiveBuffers:Receive Buffers:"256 (256)"
*RSSProfile:RSS load balancing profile:"ClosestProcessor (1)"
*SoftwareTimestamp:Software Timestamp:"Disabled (0)"
*SpeedDuplex:Speed & Duplex:"Auto Negotiation (0)"
*TransmitBuffers:Transmit Buffers:"512 (512)"
*WakeOnMagicPacket:Wake on Magic Packet:"Enabled (1)"
*WakeOnPattern:Wake on Pattern Match:"Enabled (1)"
AdaptiveIFS:Adaptive Inter-Frame Spacing:"Enabled (1)"
AutoPowerSaveModeEnabled:Link Speed Battery Saver:"Disabled (0)"
EEELinkAdvertisement:Energy Efficient Ethernet:"On (1)"
EnablePME:Enable PME:"Enabled (1)"
ITR:Interrupt Moderation Rate:"Adaptive (65535)"
LinkNegotiationProcess:Legacy Switch Compatibility Mode:"Disabled (1)"
LogLinkStateEvent:Log Link State Event:"Enabled (51)"
MasterSlave:Gigabit Master Slave Mode:"Auto Detect (0)"
ReduceSpeedOnPowerDown:Reduce Speed On Power Down:"Enabled (1)"
SipsEnabled:System Idle Power Saver:"Disabled (0)"
ULPMode:Ultra Low Power Mode:"Enabled (1)"
WaitAutoNegComplete:Wait for Link:"Auto Detect (2)"
WakeOnLink:Wake on Link Settings:"Disabled (0)"
...#SSU#...
Dineshbabu
Hi gomidas95,
Greetings!
Thank you for your response. Could you please help us with the motherboard model where the controller is embedded? or confirm if you are using a custom PCB with an I219 controller.
Dinesh
