Ethernet Products
5821 Discussions
Unable to update firmware on I225-T1
2dfx
I am trying to update the PXE code on my Intel Ethernet Adapter I225-T1.  The Intel provided BOOTUTIL properly identifies the card but despite me specifying "PXE" code as told by the utility, it claims it is an invalid choice.  Any ideas?
See attached screenshot for command entry.
B_Y
Hi @2dfx,
May we suggest you to consider following steps:
To load the image that allows to boot from the PXE, the following procedure for EFI mode needs to be followed:
1) Download the file Bootutil.zip.
2) Unzip the file Bootutil.exe.
3) Copy Bootutil.exe to a Bootable USB Stick.
4) Start the server.
5) Select the USB Stick from the Boot Menu.
6) Then type the following commands in the command line:
- bootutil (an overview of available NICs are displayed)
  bootutil -NIC=x -FE (x=a network card port, e.g. NIC=3)
1) Repeat this step for the second NIC (if available).
2) Finally, restart the server.
3) If using with a system it may take you back to the BIOS Menu.
4) Under the BOOT heading of Network Drive BBS Priorities you can now select the NICs of the network card for the above places.
5) Then select the NIC network card in the boot sequence.
6) Finally, save and exit.
We also wish to gather some information below for further checking:
1) Model of your motherboard/system
2) Did you encounter this issue previously or this is the first time?
3) Do the NIC or network adapter shown any error / unusual symbol?
4) We need your help to gather the System Support Utility log, steps as following:
https://www.intel.com/content/www/us/en/support/articles/000008563/ethernet-products.html
We'll be waiting for your response.
BY_Intel
Intel Customer Support
B_Y
Hi @2dfx,
I hope this message finds you well. I am just sending a follow up if you have any questions from the previous post. If so, please let us know. Thank you.
BY_Intel
B_Y
Hi @2dfx,
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
BY_Intel
