Ethernet Products
5719 Discussions
VLAN support for 82574L under win10
mpata
I want to create multiple VLANs using 82574L NIC on Windows 10 (1809). I think I would need the Network Adapter Drive for Windows 10 or the PROSet version of it but I can't find one that supports the NIC I have. Is there an Adapter Driver version for that specific NIC? Any other way would be good to create VLANs.
Sazirah
Hi Mate,
I believed the driver cannot be found as it came In Box Only.
We found another possible solution for your case that you may refer below:
Hyper-V (another possible way)
https://community.intel.com/t5/Ethernet-Products/Creating-Vlans-with-the-ProSet-utility-in-windows-11-not-working/m-p/1306141
Let us know if it works or you have any questions for this case.
Sazzy_Intel
IntelSupport
Community Manager
Hi mpata,
Regarding your enquiries above, I may need some details to assist you.
What is your system model brand that use Intel 82574L NIC? e.g HP/Dell Laptop/Desktop
FYI- If OEM: Your device might have customized drivers and software to enable or alter features to improve operations that are provided by the original equipment manufacturer (OEM). Contact the OEM for the latest updates and technical support information.
Regarding compatible network adapter drive that suits 82574L NIC for Windows 10, I found few information that you may refer:
1.For 82574L NIC driver that supports Windows 10, it came In Box Only, you may refer below:
Windows* support for 1 GbE Intel® Ethernet Network Controllers 82574L In Box Only for Windows 10
https://www.intel.com/content/www/us/en/support/articles/000055236/ethernet-products/gigabit-ethernet-controllers-up-to-2-5gbe.html
2.Alternatively, you may refer link below to create VLANs using Powershell:
Create VLANs in Windows® 10 Using PowerShell* (alternative)
https://www.intel.com/content/www/us/en/support/articles/000056184/ethernet-products/gigabit-ethernet-controllers-up-to-2-5gbe.html
You may try steps provided above and let me know if you need any other assistance regarding this enquiries.
Sazzy_Intel
mpata
Hi Sazzy,
Unfortunately, the OEM of my device can't help.
I would need the Intel (R) Ethernet Adapter Complete Driver Pack or the PROSet but I can't find a version that supports my NIC.
Intel® 82574L Gigabit Ethernet Controller
I would need one of those software to be able to use the PowerShell configuration too.
Do you have any other idea or can you confirm that this feature is not supported for my Windows version?
Mate
Sazirah
Hi Mate,
Sazzy_Intel
Sazirah
Hi mpata,
Good day,
This is related to your enquiries above, I would like to check if the issue has resolved?
If you have any questions or clarifications, please let me know.
Sazzy_Intel
mpata
Hi Sazzy,
Yes, I was able to solve it using Hyper-V.
Thanks for the help.
Mate
Sazirah
Hi mpata,
Thank you for your reply. We are glad that the issue has been resolved. Since the issue has resolved, we will proceed to close this case #05924243 at our end. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Sazzy_Intel
