Ethernet Products
5762 Discussions
WGI210IT- automatical production flash programming
Kowaltksi
Hello
We are using the WGI210IT module together with the Windbond_W25Q16JVSNIQ flash.
I would like to automatically record the flash with a config via our Linux system.
How is this possible?
So far I have only seen the way via lanconf64 and this way cannot be automated.
Due to the small number of flash devices, pre-programming is not possible.
Sachinks
Hello Kowaltksi,
Thank you for the details. May I ask you to confirm is Intel® Ethernet Controller I210-IT is the ethernet controller you are using? And may I know if this is a prebuilt controller or was it manually added later?
Sachin KS
Kowaltksi
Hi Sachin,
Yes we use the I210-IT ethernet controller.
We developed a new baseboard for a SMARC computer module with two I210-IT controller on separate PCIe lanes.
We therefore have new and as yet unprogrammed ETH controllers and flash modules.
Now we are looking for a way to program the flash module automatically using the INTEL tools.
So far only a manual way via the menu structure of lanconf works.
Is there a tool that can be executed via Linux using command line commands and used to program the Flash?
br Tom
Poojitha
Hello Kowaltksi,
Greetings for the day!
We kindly request you to drop your query in the embedded connectivity forum below for further assistance. Our dedicated team will provide you with comprehensive details regarding the issue you're facing.
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
If you have any questions or doubts, please reach out to us we are happy to assist you
Thank you for your understanding!
Poojitha
CarlosAM_INTEL
Hello,  @Poojitha:
We need to clarify that this forum is not related to an Intel Embedded Platform.
Due to this, the customer request is out of our scope of support.
Please consider this information when you provide the previous suggestion, or transfer any forums to the channel that you mentioned in your previous communication.
@CarlosAM_INTEL.
Poojitha
Hi Kowaltksi,
Thank you for your patience!
We request you to update 'Intel® Ethernet Flash Firmware Utility' with the link provided below and let us know the status, that will help us assist you further.
https://www.intel.com/content/www/us/en/download/15755/intel-ethernet-connections-boot-utility-preboot-images-and-efi-drivers.html
Kindly follow the procedure below to update the firmware:
https://www.intel.com/content/www/us/en/support/articles/000005790/software/manageability-products.html
If you have any questions or doubts, please reach out to us. We are happy to help you!"
Poojitha
Kowaltksi
Hi Poojitha,
Thank you for your reply.
We will try it next week and answer you then.
best regards
Tom
Sachinks
Hello Kowaltksi,
Thank you for the update. We will keep the thread open.
Sachin KS
Poojitha
Hi Kowaltksi,
I hope you are doing well. We are following up on the case. Can you please provide the latest update on the case to assist you further.
Poojitha
Kowaltksi
Hi Poojitha,
Our Linux expert is still checking whether the procedure you mentioned is fully sufficient for our application.
I think we need a few more days for this.
best regards
Tom
Sreelakshmi1
Hi Kowaltksi,
Thank you for your response. We will wait for the update.
Sreelakshmi
Poojitha
Hi Kowaltksi,
Poojitha
Kowaltksi
My colleague hasnt finished his work on this topic.
We try a lot of things with this tool together with our production system, which will take longer as expected.
Please give us some more time - maybe until end of next week.
br
Tom
Poojitha
Hi Kowaltksi,
Thank you for your response. We will wait for your further response to proceed further.
Poojitha
Poojitha
Hi Kowaltksi,
Poojitha
Poojitha
Hi Kowaltksi,
We are following up on the case. Could you please provide the latest update on the case to check and assist you further.
Poojitha
Poojitha
Hi Kowaltksi,
Poojitha
