Ethernet Products
5658 Discussões
Warning firmware error detected FWSM
Doug216
Principiante
7.755 Visualizações
I use X550T with latest firmware compiled by myself, but still not fix the Warning, my customers are complaining me. Do you have any idea or quickest way to handle this? Or I need some very specific version of the driver?
Thank you so much.
Doug216
$ more /etc/issue
Ubuntu 20.04.6 LTS
$ uname -r
5.4.0-172-generic
$ modinfo ixgbe
filename: /lib/modules/5.4.0-172-generic/updates/drivers/net/ethernet/intel/ixgbe/ixgbe.ko
version: 5.19.9
license: GPL
description: Intel(R) 10GbE PCI Express Linux Network Driver
author: Intel Corporation, <linux.nics@intel.com>
srcversion: 4A56DBA91E81F1767A7B8B8
alias: pci:v00008086d000015E5sv*sd*bc*sc*i*
And the previous version is:
# modinfo ixgbe
filename: /lib/modules/5.4.0-166-generic/kernel/drivers/net/ethernet/intel/ixgbe/ixgbe.ko
version: 5.1.0-k
license: GPL v2
description: Intel(R) 10 Gigabit PCI Express Network Driver
srcversion: 49D6E9177ADD758852F376B
But still have tones of warning like that:
Feb 26 05:14:56 308b13 kernel: [206889.800308] ixgbe 0000:62:00.0: Warning firmware error detected FWSM: 0x0118801F
Feb 26 05:14:57 308b13 kernel: [206890.216297] ixgbe 0000:62:00.1: Warning firmware error detected FWSM: 0x0118801F
11 Respostas
Azeem_Intel
Funcionário
7.727 Visualizações
Hi Douglas,
Greetings for the day!
Hope you doing well Could you please share a snapshot of the defective part with the serial number visible.
Please try the link below for the complete Ethernet driver package. If the issue persists, please share the appropriate issue details.
https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html
Best Regards
Azeem
Doug216
Principiante
7.717 Visualizações
Hi Azeem,
Thanks for your reply.
Actually, I do use the source that you listed above and I extracted ixgbe driver from PROXGB subdirectory: ixgbe-5.19.9.tar.gz, issued date is 2023/12/5, the file size is 551.2kb.
Basically I followed this blog (https://www.xmodulo.com/download-install-ixgbe-driver-ubuntu-debian.html) to make and compile it, and everything sounds smooth, except (when 'make'):
*** The target kernel has CONFIG_MODULE_SIG_ALL enabled, but
*** the signing key cannot be found. Module signing has been
*** disabled for this build.
Frankly I don't know how to use the key files.
It still has any other tricks, such as has to use a specific version of driver, or some subtle difference between X550 and X550T...i don't know.
So far, I don't has a chance to take a snapshot for the NIC, because it is in use, but not perfectly.
Thank you and need more suggestions.
Thank you.
Azeem_Intel
Funcionário
7.696 Visualizações
Hi Douglas,
Greetings for the Day!
Hope you are doing well It seems like you're encountering an issue related to module signing when compiling the ixgbe driver, And we don't have enough information for it
*** the target kernel has CONFIG_MODULE_SIG_ALL enabled, but
*** disabled for this build,
I have  shared the complete driver pack for the Intel Ethernet adapter with you, i suggest you please try to install fresh driver installation,
Please do not hesitate in contact us, we are more than glad to assist you.
Azeem.
Doug216
Principiante
7.686 Visualizações
Hello Azeem,
Thanks for your follow-up.
If I knew how to install it with signing(==key?), Ii think I have been tried already. So if you have very specific info about how to do it, ant hints, links, or intel's official step-by-step docs, I will appreciate.
Here is the 'make' output:
root@308b13:~/ixgbe-5.19.9/src# make
filtering include/linux/dev_printk.h out
filtering include/net/flow_keys.h out
filtering include/linux/device/class.h out
all files (for given query) filtered out
filtering include/linux/jump_label_type.h out
1 /* Autogenerated for Ksrc=/lib/modules/5.4.0-172-generic/build via kcompat-generator.sh */
2 #define HAVE_DEVLINK_FLASH_UPDATE_BEGIN_END_NOTIFY
3 #define HAVE_DEVLINK_HEALTH
4 #define HAVE_DEVLINK_INFO_DRIVER_NAME_PUT
5 #define HAVE_DEVLINK_PARAMS
6 #define HAVE_DEVLINK_PARAMS_PUBLISH
7 #define HAVE_DEVLINK_PORT_SPLIT
8 #define HAVE_DEVLINK_PORT_SPLIT_EXTACK
9 #define HAVE_DEVLINK_PORT_TYPE_ETH_HAS_NETDEV
10 #define HAVE_DEVLINK_REGISTER_SETS_DEV
11 #define HAVE_DEVLINK_RELOAD_ENABLE_DISABLE
12 #define NEED_DEVLINK_RESOURCES_UNREGISTER_NO_RESOURCE
13 #define NEED_DEVLINK_TO_DEV
14 #define NEED_DEVLINK_UNLOCKED_RESOURCE
15 #define HAVE_NDO_FDB_ADD_VID
16 #define HAVE_NDO_GET_DEVLINK_PORT
17 #define HAVE_NDO_UDP_TUNNEL_CALLBACK
18 #define NEED_NETIF_NAPI_ADD_NO_WEIGHT
19 #define NEED_NET_PREFETCH
20 #define NEED_ETHTOOL_SPRINTF
21 #define HAVE_ETHTOOL_FLOW_RSS
22 #define HAVE_XDP_DO_FLUSH
23 #define NEED_NO_NETDEV_PROG_XDP_WARN_ACTION
24 #define HAVE_FLOW_DISSECTOR_KEY_CVLAN
25 #define HAVE_CDEV_DEVICE
26 #define HAVE_POLL_T
27 #define HAVE_STREAM_OPEN
28 #define NEED_CLASS_CREATE_WITH_MODULE_PARAM
29 #define NEED_CLASS_CREATE_WITH_MODULE_PARAM
30 #define HAVE_GNSS_MODULE
31 #define HAVE_STRUCT_PCI_DEV_PTM_ENABLED
32 #define NEED_PCIE_PTM_ENABLED
33 #define NEED_PCI_ENABLE_PTM
34 #define NEED_PCI_AER_CLEAR_NONFATAL_STATUS
35 #define HAVE_HWMON_DEVICE_REGISTER_WITH_INFO
36 #define HAVE_IOMMU_DEV_FEAT_AUX
37 #define HAVE_STRUCT_STATIC_KEY_FALSE
38 #define NEED_LOWER_16_BITS
39 #define NEED_UPPER_16_BITS
40 #define NEED_MUL_U64_U64_DIV_U64
41 #define HAVE_MDEV_GET_DRVDATA
42 #define NEED_PTP_PARSE_HEADER
43 #define HAVE_PTP_CLOCK_INFO_ADJFINE
44 #define NEED_DIFF_BY_SCALED_PPM
45 #define NEED_DEV_PAGE_IS_REUSABLE
46 #define HAVE_TRACE_ENABLED_SUPPORT
47 #define HAVE_U64_STATS_FETCH_BEGIN_IRQ
48 #define HAVE_U64_STATS_FETCH_RETRY_IRQ
49 #define NEED_U64_STATS_READ
50 #define NEED_U64_STATS_SET
make[1]: Entering directory '/usr/src/linux-headers-5.4.0-172-generic'
CC [M] /root/ixgbe-5.19.9/src/ixgbe_main.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_api.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_common.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_dcb.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_dcb_82598.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_dcb_82599.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_ethtool.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_lib.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_mbx.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_sriov.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_param.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_phy.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_procfs.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_xsk.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_82598.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_82599.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_x540.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_x550.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_dcb_nl.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_debugfs.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_fcoe.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_ptp.o
CC [M] /root/ixgbe-5.19.9/src/ixgbe_sysfs.o
CC [M] /root/ixgbe-5.19.9/src/kcompat.o
LD [M] /root/ixgbe-5.19.9/src/ixgbe.o
Building modules, stage 2.
MODPOST 1 modules
CC [M] /root/ixgbe-5.19.9/src/ixgbe.mod.o
LD [M] /root/ixgbe-5.19.9/src/ixgbe.ko
make[1]: Leaving directory '/usr/src/linux-headers-5.4.0-172-generic'
Doug216
Principiante
7.636 Visualizações
Here is our 'live' dmesg output: every single second has a ixgbe error detected
[Wed Feb 28 00:31:15 2024] ixgbe 0000:62:00.1: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:16 2024] ixgbe 0000:62:00.0: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:17 2024] ixgbe 0000:62:00.1: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:18 2024] ixgbe 0000:62:00.0: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:19 2024] ixgbe 0000:62:00.1: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:20 2024] ixgbe 0000:62:00.0: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:21 2024] ixgbe 0000:62:00.1: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:22 2024] ixgbe 0000:62:00.0: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:23 2024] ixgbe 0000:62:00.1: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:24 2024] ixgbe 0000:62:00.0: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:25 2024] ixgbe 0000:62:00.1: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:26 2024] ixgbe 0000:62:00.0: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:27 2024] ixgbe 0000:62:00.1: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:28 2024] ixgbe 0000:62:00.0: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:29 2024] ixgbe 0000:62:00.1: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:30 2024] ixgbe 0000:62:00.0: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:31 2024] ixgbe 0000:62:00.1: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:32 2024] ixgbe 0000:62:00.0: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:33 2024] ixgbe 0000:62:00.1: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:34 2024] ixgbe 0000:62:00.0: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:35 2024] ixgbe 0000:62:00.1: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:36 2024] ixgbe 0000:62:00.0: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:37 2024] ixgbe 0000:62:00.1: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:38 2024] ixgbe 0000:62:00.0: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:39 2024] ixgbe 0000:62:00.1: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:40 2024] ixgbe 0000:62:00.0: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:41 2024] ixgbe 0000:62:00.1: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:42 2024] ixgbe 0000:62:00.0: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:43 2024] ixgbe 0000:62:00.1: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:44 2024] ixgbe 0000:62:00.0: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:45 2024] ixgbe 0000:62:00.1: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:46 2024] ixgbe 0000:62:00.0: Warning firmware error detected FWSM: 0x0118801F
[Wed Feb 28 00:31:47 2024] ixgbe 0000:62:00.1: Warning firmware error detected FWSM: 0x0118801F
Azeem_Intel
Funcionário
7.676 Visualizações
Hi Douglas,
Hope you are doing well Please try the steps below for installation. If the issue persists, please let us know, and we will escalate this matter,
https://www.intel.com/content/www/us/en/support/articles/000022174/ethernet-products.html
Note: If you purchased an OEM branded server or appliance, contact your OEM for a SW driver version that is compatible with your exact FW version. Using SW and FW versions that have not been validated to work together will affect performance, feature availability, and system stability
Azeem.
Doug216
Principiante
7.669 Visualizações
Thanks Azeem.
The attached link may not fit in my case, but still thank you for your effort.
The question I am thinking now is  the difference between the X500, X500T, and X500T1, and X500T2. And I googling/ebaying and can barely found X500T.
Again, the name of driver I need to install is for X550T:
# lspci | grep -i ethernet
62:00.0 Ethernet controller: Intel Corporation Ethernet Controller 10G X550T (rev 01)
62:00.1 Ethernet controller: Intel Corporation Ethernet Controller 10G X550T (rev 01)
but from extracted folder, there is a "readmefirst.txt":
This release includes ixgbe Linux* Base Drivers for Intel(R) Ethernet Network Connections.
The ixgbe driver supports devices based on the following controllers:
* Intel(R) Ethernet Controller 82598
* Intel(R) Ethernet Controller 82599
* Intel(R) Ethernet Controller X520
* Intel(R) Ethernet Controller X540
* Intel(R) Ethernet Controller x550    <---- x500 == x500t??
* Intel(R) Ethernet Controller X552
* Intel(R) Ethernet Controller X553
- The ixgbevf driver can only be activated on kernels that support SR-IOV. It
supports all of the above devices except for the Intel(R) Ethernet
Controller 82598.
Now I am worrying about the driver is not the one it should be: we have X550T, but I installed X550!
Because I cannot found more info about these models, so I am not sure now. But I a pretty sure: this is the only one choice: ixgbe-5.19.9.tar.gz. All others are rpm packets.
Do you have any idea about the different of the models: X500, X500T, and X500T1, and X500T2. The only thing I can guess is: the T1 is for ONE port. T2 is for 2 ports.
Sorry to post so many other staffs here, but they are related with.
Thank you.
Azeem_Intel
Funcionário
7.621 Visualizações
Hi Douglas,
Hope you are doing well. As you mentioned, you have the X550T model, and you couldn't find more information about it. Could you please share a snapshot of the defective part with the serial number visible? This will help us identify the exact model and provide you with accurate assistance. Once we receive this information, I'll be glad to help you understand the differences between the X500, X500T, X500T1, and X500T2 models.
Please feel free to contact us at any time; we are more than glad to assist you.
Azeem.
Doug216
Principiante
7.591 Visualizações
Thanks Azeem.
As for the NIC snapshot,  I am not authorized to open the server box for now, so the only thing I can do is to collect info as detail as possible from Ubuntu Server 20.04.6.
So the details are:
note1: all lshw has more than 2000 lines, so I only captured nic-related PCI. And from my screen, pci:1 and network:0 AND network:1 are tree structure, but after paste here, all tree-shape gone( html style ).
note2: I only hided my ip in "configuration" section, all others are original
*-pci:1
description: PCI bridge
product: Starship/Matisse GPP Bridge
vendor: Advanced Micro Devices, Inc. [AMD]
physical id: 3.4
bus info: pci@0000:60:03.4
version: 00
width: 32 bits
clock: 33MHz
capabilities: pci pm pciexpress msi ht normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:56 memory:b0200000-b06fffff ioport:ad400000(size=9437184)
*-network:0
description: Ethernet interface
product: Ethernet Controller 10G X550T
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:62:00.0
logical name: eno1
version: 01
serial: 74:56:3c:04:ed:9f
capacity: 10Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi msix pciexpress bus_master cap_list rom ethernet physical tp 100bt-fd 1000bt-fd 10000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=ixgbe driverversion=5.19.9 duplex=full firmware=0x80000d03, 1.1937.0 ip=xxx.yyy.aaa.bbb latency=0 link=yes multicast=yes port=twisted pair speed=10Gbit/s
resources: irq:137 memory:ad800000-adbfffff memory:adc04000-adc07fff memory:b0280000-b02fffff memory:b0600000-b06fffff memory:b0500000-b05fffff
*-network:1
physical id: 0.1
bus info: pci@0000:62:00.1
logical name: eno2
version: 01
serial: 74:56:3c:04:ed:a0
capacity: 10Gbit/s
width: 64 bits
clock: 33MHz
configuration: autonegotiation=on broadcast=yes driver=ixgbe driverversion=5.19.9 firmware=0x80000d03, 1.1937.0 latency=0 link=no multicast=yes port=twisted pair
resources: irq:291 memory:ad400000-ad7fffff memory:adc00000-adc03fff memory:b0200000-b027ffff memory:b0400000-b04fffff memory:b0300000-b03fffff
# modinfo ixgbe
version: 5.19.9
license: GPL
alias: pci:v00008086d000015E4sv*sd*bc*sc*i*
alias: pci:v00008086d000015CEsv*sd*bc*sc*i*
alias: pci:v00008086d000015CCsv*sd*bc*sc*i*
alias: pci:v00008086d000015CAsv*sd*bc*sc*i*
alias: pci:v00008086d000015C8sv*sd*bc*sc*i*
alias: pci:v00008086d000015C7sv*sd*bc*sc*i*
alias: pci:v00008086d000015C6sv*sd*bc*sc*i*
alias: pci:v00008086d000015C4sv*sd*bc*sc*i*
alias: pci:v00008086d000015C3sv*sd*bc*sc*i*
alias: pci:v00008086d000015C2sv*sd*bc*sc*i*
alias: pci:v00008086d000015AEsv*sd*bc*sc*i*
alias: pci:v00008086d000015ADsv*sd*bc*sc*i*
alias: pci:v00008086d000015ACsv*sd*bc*sc*i*
alias: pci:v00008086d000015ABsv*sd*bc*sc*i*
alias: pci:v00008086d000015B0sv*sd*bc*sc*i*
alias: pci:v00008086d000015AAsv*sd*bc*sc*i*
alias: pci:v00008086d000015D1sv*sd*bc*sc*i*
alias: pci:v00008086d00001563sv*sd*bc*sc*i*
alias: pci:v00008086d00001560sv*sd*bc*sc*i*
alias: pci:v00008086d00001558sv*sd*bc*sc*i*
alias: pci:v00008086d0000154Asv*sd*bc*sc*i*
alias: pci:v00008086d00001557sv*sd*bc*sc*i*
alias: pci:v00008086d0000154Dsv*sd*bc*sc*i*
alias: pci:v00008086d00001528sv*sd*bc*sc*i*
alias: pci:v00008086d000010F8sv*sd*bc*sc*i*
alias: pci:v00008086d0000151Csv*sd*bc*sc*i*
alias: pci:v00008086d00001529sv*sd*bc*sc*i*
alias: pci:v00008086d0000152Asv*sd*bc*sc*i*
alias: pci:v00008086d000010F9sv*sd*bc*sc*i*
alias: pci:v00008086d00001514sv*sd*bc*sc*i*
alias: pci:v00008086d00001507sv*sd*bc*sc*i*
alias: pci:v00008086d000010FBsv*sd*bc*sc*i*
alias: pci:v00008086d00001517sv*sd*bc*sc*i*
alias: pci:v00008086d000010FCsv*sd*bc*sc*i*
alias: pci:v00008086d000010F7sv*sd*bc*sc*i*
alias: pci:v00008086d00001508sv*sd*bc*sc*i*
alias: pci:v00008086d000010DBsv*sd*bc*sc*i*
alias: pci:v00008086d000010F4sv*sd*bc*sc*i*
alias: pci:v00008086d000010E1sv*sd*bc*sc*i*
alias: pci:v00008086d000010F1sv*sd*bc*sc*i*
alias: pci:v00008086d000010ECsv*sd*bc*sc*i*
alias: pci:v00008086d000010DDsv*sd*bc*sc*i*
alias: pci:v00008086d0000150Bsv*sd*bc*sc*i*
alias: pci:v00008086d000010C8sv*sd*bc*sc*i*
alias: pci:v00008086d000010C7sv*sd*bc*sc*i*
alias: pci:v00008086d000010C6sv*sd*bc*sc*i*
alias: pci:v00008086d000010B6sv*sd*bc*sc*i*
depends: dca
retpoline: Y
vermagic: 5.4.0-172-generic SMP mod_unload modversions
parm: IntMode:Change Interrupt Mode (0=Legacy, 1=MSI, 2=MSI-X), default 2 (array of int)
parm: InterruptType:Change Interrupt Mode (0=Legacy, 1=MSI, 2=MSI-X), default IntMode (deprecated) (array of int)
parm: MQ:Disable or enable Multiple Queues, default 1 (array of int)
parm: DCA:Disable or enable Direct Cache Access, 0=disabled, 1=descriptor only, 2=descriptor and data (array of int)
parm: RSS:Number of Receive-Side Scaling Descriptor Queues, default 0=number of cpus (array of int)
parm: VMDQ:Number of Virtual Machine Device Queues: 0/1 = disable (1 queue) 2-16 enable (default=8) (array of int)
parm: max_vfs:Number of Virtual Functions: 0 = disable (default), 1-63 = enable this many VFs (array of int)
parm: VEPA:VEPA Bridge Mode: 0 = VEB (default), 1 = VEPA (array of int)
parm: InterruptThrottleRate:Maximum interrupts per second, per vector, (0,1,956-488281), default 1 (array of int)
parm: LLIPort:Low Latency Interrupt TCP Port (0-65535) (array of int)
parm: LLIPush:Low Latency Interrupt on TCP Push flag (0,1) (array of int)
parm: LLISize:Low Latency Interrupt on Packet Size (0-1500) (array of int)
parm: LLIEType:Low Latency Interrupt Ethernet Protocol Type (array of int)
parm: LLIVLANP:Low Latency Interrupt on VLAN priority threshold (array of int)
parm: FdirPballoc:Flow Director packet buffer allocation level:
1 = 8k hash filters or 2k perfect filters
2 = 16k hash filters or 4k perfect filters
3 = 32k hash filters or 8k perfect filters (array of int)
parm: AtrSampleRate:Software ATR Tx packet sample rate (array of int)
parm: FCoE:Disable or enable FCoE Offload, default 1 (array of int)
parm: MDD:Malicious Driver Detection: (0,1), default 1 = on (array of int)
parm: LRO:Large Receive Offload (0,1), default 0 = off (array of int)
parm: allow_unsupported_sfp:Allow unsupported and untested SFP+ modules on 82599 based adapters, default 0 = Disable (array of int)
parm: dmac_watchdog:DMA coalescing watchdog in microseconds (0,41-10000), default 0 = off (array of int)
parm: vxlan_rx:VXLAN receive checksum offload (0,1), default 1 = Enable (array of int)
Hope this can give you more info. Thanks.
Azeem_Intel
Funcionário
7.579 Visualizações
Hi Goug216,
Hope you are doing well, As I mentioned earlier, we were unable to find more information about it, Could you please share a snapshot of the defective part with the serial number visible? This will help us identify the exact model and provide you with accurate assistance
Azeem.
Azeem_Intel
Funcionário
7.480 Visualizações
Hi Goug216,
Azeem_Intel.
Responder
