Ethernet Products
5821 Discussions
What is the X552 support for 1000baseT, SFP RJ45 transceiver? I could recognize an interface but no link gets up. It seems the ixgbe X552 driver only supports SX and LX,both having LC connector, and not 1000baseT, SFP RJ45 transceiver.
AWell15
ethtool enp4s0f0
Settings for enp4s0f0:
       Supported ports: [ TP ]
       Supported link modes:  1000baseT/Full
                               10000baseT/Full
       Supported pause frame use: Symmetric
       Supports auto-negotiation: Yes
       Advertised link modes: 1000baseT/Full
                               10000baseT/Full
       Advertised pause frame use: Symmetric
       Advertised auto-negotiation: Yes
       Speed: Unknown!
       Duplex: Unknown! (255)
       Port: Twisted Pair
       PHYAD: 0
       Transceiver: internal
       Auto-negotiation: on
       MDI-X: Unknown
       Supports Wake-on: d
       Wake-on: d
       Current message level: 0x00000007 (7)
                              drv probe link
       Link detected: no
Caguicla_Intel
Hello AWell15,
Thank you for the patience on this matter.
1.) Mentioned on the Read Me file of the X552 driver,
SFP+ devices based on the Intel(R) Ethernet Connection X552 and
Intel(R) Ethernet Connection X553 do not support the following features:
* Speed and duplex auto-negotiation.
* Wake on LAN
* 1000BASE-T SFP Modules
Intel® Network Adapter Driver for PCIe* Intel® 10 Gigabit Ethernet Network Connections Under Linux*
https://downloadcenter.intel.com/download/14687/Ethernet-Intel-Network-Adapter-Driver-for-PCIe-Intel-10-Gigabit-Ethernet-Network-Connections-Under-Linux-?product=88208
You may visit this link as a reference of the Read me file of the driver above.
https://downloadmirror.intel.com/14687/eng/readme.txt
2.) Since this is an Ethernet controller that's embedded with Kontron system, it would be best if you can get in touch with Kontron for further support since they have customized drivers and software to enable or alter features on your system. It is recommended to contact them for the transceiver supported on your system. They are in best position where you can seek assistance so you don’t lose features or customizations of the Ethernet controller. Please visit this link for Support Options for Intel® Ethernet Controllers
https://www.intel.com/content/www/us/en/support/articles/000006628/network-and-io/ethernet-products.html
3.) For further assistance regarding the driver, please post a request on the sourceforge link below.
https://sourceforge.net/projects/e1000/
Let us know if you have additional questions and clarifications on this matter.
Hoping to hear from you.
Crisselle C
Intel Customer Support
A Contingent Worker at Intel
Caguicla_Intel
Hello AWell15,
Thank you for posting in Intel Ethernet Communities. Please provide the following details for us to check on your request.
1.) Exact model of your adapter. You may provide the markings so we can double check on it. Kindly refer to the link below on where to find the PBA of the adapter. It is a 6-digit number located at the last part of the serial number.
https://www.intel.com/content/www/us/en/support/articles/000007022/network-and-io/ethernet-products.html
2.) What is that exact driver version you used. You may share the link on where you downloaded the driver.
3.) What is the cable type used?
Crisselle C
AWell15
Hi Crissell C,
Q1) Exact model of your adapter. You may provide the markings so we can double check on it.
A1) The X552 is built into the Kontron me1100 mother board.
Q2) What is that exact driver version you used. You may share the link on where you downloaded the driver.
A2) https://sourceforge.net/projects/e1000/files/ixgbe%20stable/5.6.3/
Q3) What is the cable type used?
A3) Common internet RJ45 copper TP cable.
Does Intel have any updated ixgbe x550 drivers, ixgbe_x550.c, supporting 1GBASET and not only 1GBASESX and 1GBASELX?
#define IXGBE_SFF_1GBASESX_CAPABLE 0x1
#define IXGBE_SFF_1GBASELX_CAPABLE 0x2
#define IXGBE_SFF_1GBASET_CAPABLE 0x8
BR,
AWell15
Caguicla_Intel
Hello AWell15,
Thank you for the reply.
Please allow us to check on this. Rest assured that we will get back to you within 1-3 business days.
Hoping for your patience.
Crisselle C
AWell15
Hi Crisselle C,
Thank you for the update.
BR,
AWell15
Caguicla_Intel
Hello AWell15,
* Wake on LAN
Crisselle C
AWell15
Hi Crisselle C,
Thank you for the reply answering my question.
AWell15
Mike_Intel
Hello AWell15,
Thank you for the confirmation. Do you have additional questions or clarifications or is it okay if we can close this thread now? We will wait for your reply.
Michael L.
Intel Customer Support Technicians
AWell15
Hi Michael L,
It is okay to close this thread.
AWell15
