Hello All,
I have 4 port X710 card
[root@localhost vcr]# lsmod | grep i40e
i40evf 73728 0
i40e 315392 0
geneve 28672 1 i40e
vxlan 40960 2 i40e,ixgbe
ptp 20480 3 igb,i40e,ixgbe
[root@localhost vcr]# modinfo i40e
filename: /lib/modules/4.5.5-201.fc23.x86_64/kernel/drivers/net/ethernet/intel/i40e/i40e.ko.xz
version: 1.5.16
license: GPL
description: Intel(R) 40-10 Gigabit Ethernet Connection Network Driver
author: Intel Corporation, <</span>mailto:e1000-devel@lists.sourceforge.net e1000-devel@lists.sourceforge.net>
srcversion: D50DB0062A90F6C369842D1
alias: pci:v00008086d00001588sv*sd*bc*sc*i*
alias: pci:v00008086d00001587sv*sd*bc*sc*i*
alias: pci:v00008086d00001589sv*sd*bc*sc*i*
alias: pci:v00008086d00001586sv*sd*bc*sc*i*
alias: pci:v00008086d00001585sv*sd*bc*sc*i*
alias: pci:v00008086d00001584sv*sd*bc*sc*i*
alias: pci:v00008086d00001583sv*sd*bc*sc*i*
alias: pci:v00008086d00001581sv*sd*bc*sc*i*
alias: pci:v00008086d00001580sv*sd*bc*sc*i*
alias: pci:v00008086d00001574sv*sd*bc*sc*i*
alias: pci:v00008086d00001572sv*sd*bc*sc*i*
depends: geneve,ptp,vxlan
vermagic: 4.5.5-201.fc23.x86_64 SMP mod_unload
parm: debug:Debug level (0=none,...,16=all) (int)
[root@localhost vcr]# modinfo i40evf
filename: /lib/modules/4.5.5-201.fc23.x86_64/kernel/drivers/net/ethernet/intel/i40evf/i40evf.ko.xz
version: 1.5.14
license: GPL
description: Intel(R) 40-10 Gigabit Ethernet Virtual Function Driver
author: Intel Corporation, <</span>mailto:linux.nics@intel.com linux.nics@intel.com>
srcversion: 522158BAB323575B03D48C8
alias: pci:v00008086d0000154Csv*sd*bc*sc*i*
depends:
host - fedora 23 kernel 4.5.5
guest OS is FreeBSD9.3 and VF driver for FreeBSD is 1.2.11(latest).
ixlv0: mem 0xfeb60000-0xfeb6ffff,0xfebe0000-0xfebe3fff at device 9.0 on pci0
ixlv1: mem 0xfeb70000-0xfeb7ffff,0xfebe4000-0xfebe7fff at device 11.0 on pci0
ixlv2: mem 0xfeb80000-0xfeb8ffff,0xfebe8000-0xfebebfff at device 12.0 on pci0
ixlv3: mem 0xfeb90000-0xfeb9ffff,0xfebec000-0xfebeffff at device 13.0 on pci0
ixlv4: mem 0xfeba0000-0xfebaffff,0xfebf0000-0xfebf3fff at device 14.0 on pci0
ixlv5: mem 0xfebb0000-0xfebbffff,0xfebf4000-0xfebf7fff at device 15.0 on pci0
ixlv6: mem 0xfebc0000-0xfebcffff,0xfebf8000-0xfebfbfff at device 16.0 on pci0
ixlv7: mem 0xfebd0000-0xfebdffff,0xfebfc000-0xfebfffff at device 17.0 on pci0
I have configured 2 ports each with 4 VF so in total i am getting only ~100Mbps which way less than what i get from virtio.
My performance per VF is ~10Mbps and 4 VFs are getting only 40Mbps/port however i am providing close to 2.5Gbps pcap
Also i have upgraded firmware to latest, 5.04
[73053.043664] i40e 0000:aa:00.3: fw 5.0.40043 api 1.5 nvm 5.04 0x800024da 0.0.0
is there anything i am doing wrong? What's official/profiled per VF performance in the guest.
Thank you in advance
-chintu-
Hi Chintu,
Thank you forr the post. I can see you are using the latest VF 1.2.11 at https://downloadcenter.intel.com/download/25161/Network-Adapter-Virtual-Function-Driver-for-40-Gigabit-Network-Connections-under-FreeBSD-
What is the switch model used? Have you check also on the switch setting?
I will further check on your inquiry.
rgds,
wb
Hi Chintu,
Please help confirm if you are using X710 or XL710 network adapter?
You may refer to the correct driver for X710 server adapter under FreeBSD*:
Network Adapter Driver for PCI-E* 10 Gigabit Network Connections under FreeBSD*:
https://downloadcenter.intel.com/download/26004 (Virtual function)
version 1.4.6
https://downloadcenter.intel.com/download/14688
version: 3.1.14
What is the switch model ?
wb
Thanks for the reply wb.
I have both 4 port X710 and 2 port XL710 adapters.
-chintu-
wb,
for X710 cards,
i tried using if_ixv.ko in FreeBSD guest.
8 1 0xffffffff81a6d000 1baa0 mrsas.ko
9 1 0xffffffff81a89000 390c8 if_ixv.ko
and KVM host has
version: 1.5.14
after that i can't even see any interface detected in my VM.
[root@App46005 ~]# ifconfig
vtnet0: flags=8843 metric 0 mtu 1500
options=6c03bb
ether 52:54:00:30:a0:c0
inet 192.168.63.50 netmask 0xffffff00 broadcast 192.168.63.255
nd6 options=29
media: Ethernet 10Gbase-T
status: active
lo0: flags=8049 metric 0 mtu 16384
options=600003
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x6
inet 127.0.0.1 netmask 0xff000000
nd6 options=21
ipfw0: flags=8801 metric 0 mtu 65536
nd6 options=21
pflog0: flags=100 metric 0 mtu 33152
nd6 options=29
this is my interface configuration
-chintu-
wb,
how do i get the switch version?
What exactly is the switch version?
-chintu-
Hi Chintu,
What is the brand or model of your switch? (example is it a Cisco switch, what model?)
wb
Hi Chintu,
Please confirm if you have updated the VF driver to the version on our website below:
version 1.4.6
https://downloadcenter.intel.com/download/26004/Intel-Network-Adapter-Virtual-Function-Driver-for-PCI-E-10-Gigabit-Network-Connections-under-FreeBSD-
thanks,
wb
Hi Chintu,
I would like to follow up if you have updated the VF driver version 1.4.6 on our website below:
Looking forward to your update.
wb
