Ethernet Products
5760 Discussions
X/L710, FreeBSD VF per VF performance
cheta
Hello All,
I have 4 port X710 card
[root@localhost vcr]# lsmod | grep i40e
i40evf 73728 0
i40e 315392 0
geneve 28672 1 i40e
vxlan 40960 2 i40e,ixgbe
ptp 20480 3 igb,i40e,ixgbe
[root@localhost vcr]# modinfo i40e
filename: /lib/modules/4.5.5-201.fc23.x86_64/kernel/drivers/net/ethernet/intel/i40e/i40e.ko.xz
version: 1.5.16
license: GPL
description: Intel(R) 40-10 Gigabit Ethernet Connection Network Driver
author: Intel Corporation, <</span>mailto:e1000-devel@lists.sourceforge.net e1000-devel@lists.sourceforge.net>
srcversion: D50DB0062A90F6C369842D1
alias: pci:v00008086d00001588sv*sd*bc*sc*i*
alias: pci:v00008086d00001587sv*sd*bc*sc*i*
alias: pci:v00008086d00001589sv*sd*bc*sc*i*
alias: pci:v00008086d00001586sv*sd*bc*sc*i*
alias: pci:v00008086d00001585sv*sd*bc*sc*i*
alias: pci:v00008086d00001584sv*sd*bc*sc*i*
alias: pci:v00008086d00001583sv*sd*bc*sc*i*
alias: pci:v00008086d00001581sv*sd*bc*sc*i*
alias: pci:v00008086d00001580sv*sd*bc*sc*i*
alias: pci:v00008086d00001574sv*sd*bc*sc*i*
alias: pci:v00008086d00001572sv*sd*bc*sc*i*
depends: geneve,ptp,vxlan
vermagic: 4.5.5-201.fc23.x86_64 SMP mod_unload
parm: debug:Debug level (0=none,...,16=all) (int)
[root@localhost vcr]# modinfo i40evf
filename: /lib/modules/4.5.5-201.fc23.x86_64/kernel/drivers/net/ethernet/intel/i40evf/i40evf.ko.xz
version: 1.5.14
license: GPL
description: Intel(R) 40-10 Gigabit Ethernet Virtual Function Driver
author: Intel Corporation, <</span>mailto:linux.nics@intel.com linux.nics@intel.com>
srcversion: 522158BAB323575B03D48C8
alias: pci:v00008086d0000154Csv*sd*bc*sc*i*
depends:
host - fedora 23 kernel 4.5.5
guest OS is FreeBSD9.3 and VF driver for FreeBSD is 1.2.11(latest).
ixlv0: mem 0xfeb60000-0xfeb6ffff,0xfebe0000-0xfebe3fff at device 9.0 on pci0
ixlv1: mem 0xfeb70000-0xfeb7ffff,0xfebe4000-0xfebe7fff at device 11.0 on pci0
ixlv2: mem 0xfeb80000-0xfeb8ffff,0xfebe8000-0xfebebfff at device 12.0 on pci0
ixlv3: mem 0xfeb90000-0xfeb9ffff,0xfebec000-0xfebeffff at device 13.0 on pci0
ixlv4: mem 0xfeba0000-0xfebaffff,0xfebf0000-0xfebf3fff at device 14.0 on pci0
ixlv5: mem 0xfebb0000-0xfebbffff,0xfebf4000-0xfebf7fff at device 15.0 on pci0
ixlv6: mem 0xfebc0000-0xfebcffff,0xfebf8000-0xfebfbfff at device 16.0 on pci0
ixlv7: mem 0xfebd0000-0xfebdffff,0xfebfc000-0xfebfffff at device 17.0 on pci0
I have configured 2 ports each with 4 VF so in total i am getting only ~100Mbps which way less than what i get from virtio.
My performance per VF is ~10Mbps and 4 VFs are getting only 40Mbps/port however i am providing close to 2.5Gbps pcap
Also i have upgraded firmware to latest, 5.04
[73053.043664] i40e 0000:aa:00.3: fw 5.0.40043 api 1.5 nvm 5.04 0x800024da 0.0.0
is there anything i am doing wrong? What's official/profiled per VF performance in the guest.
Thank you in advance
-chintu-
Hi Chintu,
Thank you forr the post. I can see you are using the latest VF 1.2.11 at https://downloadcenter.intel.com/download/25161/Network-Adapter-Virtual-Function-Driver-for-40-Gigabit-Network-Connections-under-FreeBSD-
What is the switch model used? Have you check also on the switch setting?
I will further check on your inquiry.
rgds,
wb
cheta
Wb,
What do you mean by switch version?
-chintu-
Hi Chintu,
Please help confirm if you are using X710 or XL710 network adapter?
You may refer to the correct driver for X710 server adapter under FreeBSD*:
Network Adapter Driver for PCI-E* 10 Gigabit Network Connections under FreeBSD*:
https://downloadcenter.intel.com/download/26004 (Virtual function)
version 1.4.6
https://downloadcenter.intel.com/download/14688
version: 3.1.14
What is the switch model ?
wb
cheta
Thanks for the reply wb.
I have both 4 port X710 and 2 port XL710 adapters.
-chintu-
cheta
wb,
for X710 cards,
i tried using if_ixv.ko in FreeBSD guest.
8 1 0xffffffff81a6d000 1baa0 mrsas.ko
9 1 0xffffffff81a89000 390c8 if_ixv.ko
and KVM host has
version: 1.5.14
after that i can't even see any interface detected in my VM.
[root@App46005 ~]# ifconfig
vtnet0: flags=8843 metric 0 mtu 1500
options=6c03bb
ether 52:54:00:30:a0:c0
inet 192.168.63.50 netmask 0xffffff00 broadcast 192.168.63.255
nd6 options=29
media: Ethernet 10Gbase-T
status: active
lo0: flags=8049 metric 0 mtu 16384
options=600003
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x6
inet 127.0.0.1 netmask 0xff000000
nd6 options=21
ipfw0: flags=8801 metric 0 mtu 65536
nd6 options=21
pflog0: flags=100 metric 0 mtu 33152
nd6 options=29
this is my interface configuration
-chintu-
cheta
wb,
how do i get the switch version?
What exactly is the switch version?
-chintu-
Hi Chintu,
What is the brand or model of your switch? (example is it a Cisco switch, what model?)
wb
Hi Chintu,
Please confirm if you have updated the VF driver to the version on our website below:
version 1.4.6
https://downloadcenter.intel.com/download/26004/Intel-Network-Adapter-Virtual-Function-Driver-for-PCI-E-10-Gigabit-Network-Connections-under-FreeBSD-
thanks,
wb
Hi Chintu,
I would like to follow up if you have updated the VF driver version 1.4.6 on our website below:
Looking forward to your update.
wb
