Ethernet Products
5821 Discussions
X540 Pinout Spreadsheet
Does Intel offer pin-out spreadsheets for chipsets? Specifically I need a pin-out spreadsheet for the X540 to facilitate the build of a symbol in OrCAD. Thanks.
st4
New Contributor III
Hi Pete42,
Not sure if you have gone through the X540 ethernet controller datasheet,
http://www3.intel.com/content/dam/www/public/us/en/documents/datasheets/ethernet-x540-datasheet.pdf http://www3.intel.com/content/dam/www/public/us/en/documents/datasheets/ethernet-x540-datasheet.pdf
Please update me if the above meets your requirment so that I can further check for you.
wb
