Ethernet Products
5762 Discussions
X550 Driver for Windows 10 (10.0.14393) WOL (Wake on LAN) not working
KBeck3
When I install the driver ver 21.1 https://downloadcenter.intel.com/download/25016/Network-Adapter-Driver-for-Windows-10 Download Intel® Network Adapter Driver for Windows® 10 I get a message
"Important Note: Creating Intel® ANS teams and VLANs on Microsoft Windows® 10 is currently not supported. As a result, when created, teams and VLANs do not pass traffic. We expect that ANS will be supported on Microsoft Windows 10 client in a future release"
I dont need teaming etc...but once the driver is installed, I dont see WOL in the ADVANCED option ???
Where is the WOL feature???
Hi Inukshuk,
Thank you for the post. The WOL feature is not available as currently Windows 10 does not support the Advance Teaming and VLAN features (which were supported in previous older Windows version).
Please refer to the announcement on our website for Windows 10 driver download site (which similar to the message you encountered)
https://downloadcenter.intel.com/download/25016/Intel-Network-Adapter-Driver-for-Windows-10
"Creating Intel ANS teams and VLANs on Windows® 10 is currently not supported. As a result, when created, teams and VLANs do not pass traffic. We expect that ANS will be supported on Windows 10 client in a future release."
wb
KBeck3
Ok then what card (chipset) X540 ? will work with Windows 10.0.14393 (64bit) ...and or when are going to release the new driver with Wake on Lan feature ???
Hi Inukshuk,
I am sorry currently there is no full support driver of Intel network adapters X540 in Windows* 10, and we do not have the timeline for the ANS feature, we expect that ANS will be supported on Windows 10 client in a future release.
Apologize for the inconvenience this might have caused.
rgds,
wb
Hi Inukshuk,
For the wake on lan, you can use the options in power management - wake on magic packet, please check this out if could be of use to you.
rgds,
wb
Hi Inukshuk,
As additional FYI. There will be a new software release version 22.0 which will bring back
the support for ANS in Windows 10. Please refer to this comm. post for reference
https://communities.intel.com/thread/77934?start=345&tstart=0 https://communities.intel.com/thread/77934?start=345&tstart=0
Hope this helps.
rgds,
wb
Hi Inukshuk,
Please feel free to update me if further assistance needed ? thanks.
rgds,
wb
KBeck3
Well its been 4 months now when is the ver. 22 going to be released?
Hi Inukshuk,
Thanks for the follow up. It will be on February, please refer to this post.
https://communities.intel.com/thread/77934?start=360&tstart=0 https://communities.intel.com/thread/77934?start=360&tstart=0
rgds,
wb
KBeck3
I have downloaed and instaleed Release 22...I still DONT see Wake on LAN for the X550 ???
Is it hidden, please explain where it is...
Hi Inukshuk,
Let me double check for you. Thanks.
rgds,
wb
Hi Inukshuk,
Can you share more information about the WOL option, under normal scenario, there should be a wake on option such as "wake on magic packet" under "power management" tab in the adapter properties.
What is the exact driver installed / appeared on your NIC?
Please also provide the exact 550 model, is it a standalone NIC or onboard NIC? What is the brand and model of the board if it is onboard NIC?
wb
KBeck3
Seriouslly...READ the above message ??? all is in the thread...
Intel X550 Single Port Single Card Version 22 file...
Device Property says date 12/16/16 version 4.1.4.0...is this the file verion from Version 22 ???
KBeck3
and I dont have 2 WEEKS for REPLYs...or I will return 10G Card and use another brand..
Hi Inukshuk, Based on the description you are using x550-T1 network adapter as this is the single port NIC for x550 series. let me double check. rdgs, wb
KBeck3
? What is the answer to Wake on LAN for version 22.0.1
Windows 10.0.14393 64Bit
X550-T1 (Windows shows Driver 4.1.4.0) ?
there is no section where I see Wake on LAN
HI Inukshuk,
Apologies for the delay. I am still checking on this.
rgds,
wb
Hi Inukshuk,
Further checking 10 Gigabit adapter does not support WOL as stated at http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005793.html
However based on our READme information https://downloadmirror.intel.com/19186/eng/readme.txt
"The Intel(R) Ethernet Converged Network Adapter X550-T1 and Intel(R) Ethernet Converged Network Adapter X550-T2 have a manageability/AUX power connector. These devices only support WoL if AUX power is supplied via this connector. Note that this is system and adapter specific. Some with this connector do not support WoL. Some systems do not provide the correct power connection. See your system documentation for details."
Please help check with your system vendor if the system comes with aux power
connector and supports WOL.
rgds,
wb
Hi Inukshuk,
Please feel free to update me if you need further assistance.
Rgds,
wb
