Ethernet Products
5608 Discussions
X550-T2 PCIe 2.0 x4
RKrus
Hello, I'm looking around for an answer to this question and want to confirm something before making a good (or bad) decision...
The specs for the X550-T2 requires a PCIe 3.0 x4 slot; the X540-T2 required a PCIe 2.0 x8 slot I read online.
My motherboard currently only has one PCIe 2.0 x4 slot available. Would the X550-T2 still work with one 10G connector using PCIe 2.0 and in the future I can upgrade to a PCIe 3.0 and then use both? Or would the X550-T2 not function correctly under PCIe 2.0?
Thanks!
Hi Krusher_r,
Thank you for posting in Wired Communities. The network adapter is backward compatible to the PCI-E 2.0 slot. As there are many factors affecting the network performance, it is recommended to use the network adapter to a slot that matches or exceeds the bus width of the adapter. Please refer to this website for reference:
https://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005811.html
It will work still if you are referring swapping the X550-T2 to the supported PCIe 3.0 slot in the future. Please contact your motherboard support to check if the X550-T2 is compatible to your board system. Hope the above information help.
Sharon
Hi Krusher_r,
Sharon
RKrus
Thanks for confirming that Sharon; I figured it was likely the case that a single 10G connector would work in a PCIe 2.0 x4 slot for now and then both could be used in a PCIe 3.0 x4 slot in the future as you've stated. My motherboard is older and I doubt that anything this new would be tested on it for compatibility.
Due to the PCIe 2.0's encoding scheme that is less efficient, each lane delivers 4Gbit/s each direction for a total of 16Gbit/s. As there is overhead involved, one 10G connector won't use all 16Gbit/s itself but both would easily exceed it and then some. I just wanted to be sure that the card would handle this scenario for now; with Intel's driver support and lifetime warranty it'll be good for many years to come when I make the upgrade.
Edit: 4x4=16; I used the original unencoded 4x5=20 (fixed it above).
Hi Krusher_r,
Thank you for the information and you are welcome
Sharon
