Ethernet Products
5721 Discussions
X550BT2 does not work with IXGBE 4.3.15.
hi there.
"Network Adapter Driver for PCI-E * Intel® 10 Gigabit Ethernet Network Connections under Linux * Version: 4.3.15 (Latest)" was introduced, X550BT2 does not work.
WEB-Site
https://downloadcenter.intel.com/download/14687/Network-Adapter-Driver-for-PCI-E-Intel-10-Gigabit-Ethernet-Network-Connections-under-Linux-
This download is valid for the product (s) listed below.
"Intel® Ethernet Controller X550-BT2"
Status
Linux Kernel Version: 3.9.0
Target Device: X550BT2
console operation
$ lspci -d 8086:
01:00.0 Ethernet controller: Intel Corporation Device 1562 (rev 01)
01:00.1 Ethernet controller: Intel Corporation Device 1562 (rev 01)
$ lspci -nd 8086:
01:00.0 0200: 8086:1562 (rev 01)
01:00.1 0200: 8086:1562 (rev 01)
$ ifconfig -a
eth0 Link encap:Ethernet HWaddr XX:XX:XX:XX:XX:XX
inet addr:192.168.32.139 Bcast:192.168.32.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:3018 errors:0 dropped:10 overruns:0 frame:0
TX packets:1453 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:313400 (306.0 KiB) TX bytes:231368 (225.9 KiB)
Interrupt:54 Base address:0xb000
lo Link encap:Local Loopback
LOOPBACK MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
$ insmod ./ixgbe.ko
Intel(R) 10 Gigabit PCI Express Network Driver - version 4.3.15
Copyright (c) 1999-2015 Intel Corporation.
$ ifconfig -a
Hi Kazuveri,
Just want to double check if you encountered any error message when you loaded the driver?
rgds,
wb
Hi Intel Corporation,
Error message is not output.
Exit code is also 0.
$ insmod ./ixgbe.ko
$ echo $?
0
$ lsmod
ixgbe 246315 0 - Live 0xbf0a2000 (O)
It does not exist DEV-ID 0x1562 in the header.
$ grep 1562 ixgbe_type.h
$ grep IXGBE_DEV_ID_X550 ixgbe_type.h
# define IXGBE_DEV_ID_X550T 0x1563
# define IXGBE_DEV_ID_X550T1 0x15D1
# define IXGBE_DEV_ID_X550EM_X_KX4 0x15AA
# define IXGBE_DEV_ID_X550EM_X_KR 0x15AB
# define IXGBE_DEV_ID_X550EM_X_SFP 0x15AC
# define IXGBE_DEV_ID_X550EM_X_10G_T 0x15AD
# define IXGBE_DEV_ID_X550EM_X_1G_T 0x15AE
HI Kazuveri,
Thank you for the info. I will check on this.
rgds,
wb
Hi Kazuveri,
Please try the driver at below URL
https://sourceforge.net/projects/e1000/files/ixgbe%20stable/4.4.6/
wb
Hi Kazuveri,
Have you tried the driver posted on my previous post? Please feel free to update me.
thanks,
wb
The problem is resolved.
Cause EEPROM is was not set.
Thank you very much.
Hi Kazuveri,
Thank you for the update and glad the issue is fixed.
rgds,
wb
