Hi, I have several X710-DA4 that I purchased at different times, and some of them I was able to grab the latest firmware (5.05) and upgrade them. nvmupdate64e and ethool show this on the good ones:
driver: i40e
version: 1.6.42
firmware-version: 5.05 0x8000289d 1.1568.0
bus-info: 0000:85:00.2
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [.........*]
Num Description Ver. DevId S:B Status
01) Intel(R) Ethernet Converged Network 5.05 1572 00:004 Up to date
Adapter X710-4
02) Intel(R) I350 Gigabit Network Connection 1.99 1521 00:129 Update not
available
03) Intel(R) Ethernet Converged Network 5.05 1572 00:133 Up to date
Adapter X710-4
On the other box, it will not let me upgrade:
driver: i40e
version: 2.0.23
firmware-version: 4.10 0x800011c5 0.0.0
bus-info: 0000:01:00.1
supports-test: yes
Inventory in progress. Please wait [|.........]
01) Intel(R) Ethernet Converged Network 4.10 1572 00:001 Update not
Adapter X710-4 available
available
03) Intel(R) Ethernet Converged Network 4.10 1572 00:130 Update not
Does anyone know what's wrong?
Hi cburdick,
Thank you for posting in Wired Ethernet Community.
Please share the output of lspci -vv | grep -i 'Intel Corporation Ethernet Controller X710'
regards,
Vince
01:00.0 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
01:00.1 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
01:00.2 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
01:00.3 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
82:00.0 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
82:00.1 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
82:00.2 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
82:00.3 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
Hi cburdick,
Thanks for sharing the lspci output, I was looking for the following items ([SN], [V1]) to determine if your X710 is retail or OEM.
You can try to load version 4.42 then version 5.05.
Download link to version 4.42
https://downloadcenter.intel.com/download/25222/Non-Volatile-Memory-NVM-Update-Utility-for-Intel-Eth...
regards,
Vince
Hi Vince, same results:
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.25.20.12
Copyright (C) 2013 - 2015 Intel Corporation.
WARNING: TO AVOID DAMAGE TO YOUR DEVICE, DO NOT EXIT OR REBOOT OR POWER OFF THE SYSTEM DURING THIS UPDATE
Inventory in progress. Please wait [+.........]
Num Description Device-Id B:D Adapter Status
01) Intel(R) Ethernet Converged Network Ad 8086-1572 01:00 Update not available
02) Intel(R) I350 Gigabit Network Connecti 8086-1521 129:00 Update not available
03) Intel(R) Ethernet Converged Network Ad 8086-1572 130:00 Update not available
Tool execution completed with the following status: All operations completed successfully
Press any key to exit.
Hi cburdick, please share the markings of your Intel(R) X710, this information is available in the white sticker label in the actual network adapter.
regards,
Vince
Hi, the white sticker is in the attached picture.
Thanks cburdick, please try to run this command during firmware update.
./nvmupdate64e -u -l -o update.xml -b -c nvmupdate.cfg
regards,
Vince
Hi Vince, that doesn't seem to work:
~/XL710/Linux_x64$ sudo ./nvmupdate64e -u -l -o update.xml -b -c nvmupdate.cfg
NVMUpdate version 1.28.19.4
Copyright (C) 2013 - 2016 Intel Corporation.
Config file read.
No devices to update
Post update inventory
Hi Cburdick,
Unfortunately we are not able to locate the PBA # H34308-003 in our part number website below:
https://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005612.html
Can you run the lspci command to provide the vendor ID and Dev ID for us to double check? You may click on the arrow beside "Linux" to expand the entry to see the sample command and output detail at website above.
Type lspci -nn | grep -i 'Ethernet Controller' at a command prompt.
Looking forward to your reply. Thank you.
sharon
Hi, none of that information is shown in lspci; it's all blank:
Capabilities: [e0] Vital Product Data
Product Name: XL710 40GbE Controller
Read-only fields:
[PN] Part number:
[EC] Engineering changes:
[FG] Unknown:
[LC] Unknown:
[MN] Manufacture ID:
[PG] Unknown:
[SN] Serial number:
[V0] Vendor specific:
[RV] Reserved: checksum good, 0 byte(s) reserved
Read/write fields:
[V1] Vendor specific:
End
01:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
01:00.1 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
01:00.2 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
01:00.3 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
81:00.0 Ethernet controller [0200]: Intel Corporation I350 Gigabit Network Connection [8086:1521] (rev 01)
81:00.1 Ethernet controller [0200]: Intel Corporation I350 Gigabit Network Connection [8086:1521] (rev 01)
82:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
82:00.1 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
82:00.2 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
82:00.3 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
Hi Cburdick,
Please feel free to provide the information requested. Looking forward to your reply. Thank you.
sharon
Hi Sharon, I have responded several days ago, but it says the response is being moderated. Here it is again:
Read-only fields:
[PN] Part number:
[FG] Unknown:
[LC] Unknown:
[PG] Unknown:
[SN] Serial number:
Read/write fields:
End
Hi Cburdick,
Thank you for the information and taking time to resend the information. Based on the output, there is no device and vendor ID information. Just to double check if this network adapter came with the server you bought? I understand you bought several units of this model in separate time, however one of these network adapter came along with the server system? What is the brand and model of your server system?
sharon
Hi, the cards were purchased with the server from exxact computing. The model is:
TXR430-1500R chassis:https://exxactcorp.com/index.php/solution/solu_detail/198 https://exxactcorp.com/index.php/solution/solu_detail/198
HI Cburdick,
Thank you for the information.
regards,
sharon
Hi Cburdick,
Here is a suggestion you can try. Please run the SSU tool to check for the Etrack ID then follow the steps below. You can download the SSU tool here at
https://downloadcenter.intel.com/product/91600/Intel-System-Support-Utility
1. Unpack the XL710_NVMUpdatePackage_v5_05 for whatever version you are using (Just extract the contents to a folder)
2. Open the extracted folder and go to XL710 | Linux_x64 and locate "nvmupdate.cfg"
3. Open the "nvmupdate.cfg" with a text editor
4. Search for the following full entry: (search for EEPID: 800024C6 to make it easier to find)
BEGIN DEVICE
DEVICENAME: XL710
VENDOR: 8086
DEVICE: 1572
NVM IMAGE: X710DA2_5p04_CFGID7p2_OEMGEN.bin
SKIP OROM: TRUE
EEPID: 800024C6
REPLACES: 8000191B 80001920 80001DC0 80001F54 80001FA4 80002282
EEPROM MAP: PF_Alloc_WOL_DIS.txt
RESET TYPE: REBOOT
END DEVICE
5. On the line that says "REPLACES:" add your network adapter's ETrackID at the end of the listed ETrack IDs
6. Save the file.
Please do let me know the result. Thank you for your time on this matter.
regards,
sharon
Hi Sharon, it doesn't look like SSU is supported on Ubuntu 14.04:
~$ sudo ./ssu.sh
This product is not supported on this operating system.
Would you like to try to scan? (y/n)
y
It hangs here and doesn't move after that.
Hi Cburdick,
Thank you for the update. Let me further check.
regards,
sharon
Hi Cburdick,
For the Etrack ID, please refer to page 4 of the userguide below, you may run the ethtool command to generate the output
https://www-ssl.intel.com/content/www/us/en/embedded/products/networking/nvm-update-tool-quick-linux...
sharon
