Ethernet Products
5279 Discussions
X710-T2L NVM update failed to 9.40
Boombo
Hey, we have 10 servers and each server has 2 piece of X710-T2L nics. Only 1 of them failed while nvm update and now i get any connection or 100mbps max speed connection. Sometimes nic recognise if there is a connection sometimes not. No 10G speeds. To try nvm updates again i put it on my old PC. I tried reinstalling 9.40 and 9.50 tried revert back to 7.20&9.10. I just need to get 9.40 update.
I used these links to download
Intel-downgrade-dl
Intel-DL-links
In attachment you can find SSU report, label and connection speed tab
reapplying update 9.50 to 9.50
Num Description                          Ver.(hex)  DevId S:B    Status
01) Intel(R) Ethernet Network Adapter   9.80(9.50)   15FF 00:002 Update
    X710-T2L                                                     available
Options: Adapter Index List (comma-separated), [A]ll, e[X]it
Enter selection: 1
Would you like to back up the NVM images? [Y]es/[N]o: n
Update in progress. This operation may take several minutes.
01) Intel(R) Ethernet Network Adapter   9.80(9.50)   15FF 00:002 Update failed
    X710-T2L
Tool execution completed with the following status: An error occurred when updating a firmware module.
Press any key to exit.
reverting back 9.50 to 9.10
01) Intel(R) Ethernet Network Adapter     N/A(N/A)   15FF 00:002 Update
    X710-T2L                                                     available
Enter selection: 1
    X710-T2L                                                     successful
Tool execution completed with the following status: The tool cannot find the correct preservation rules in the NVM on the device. User settings cannot be preserved with this update. To update the NVM, overwrite the user settings by using the '-rd' switch to skip setting preservation.
 reverting back 9.50 to 9.10 with -rd
    X710-T2L                                                     available
Enter selection: 1
01) Intel(R) Ethernet Network Adapter   9.16(9.10)   15FF 00:002 Update failed
    X710-T2L
Boombo
Any suggestion?
