Ethernet Products
5736 Discussions
bring up method of I350-AM2 ?
HJung8
Hello!
We are using I350-AM2 with Freescale i.MX6Q, and i have some questions.
1. Can i use I350-AM2 without EEPROM?
2. If i cannot use I350-AM2 without EEPROM, how can i write EEPROM after booting completed?
3. Is there any reference EEPROM data? Or can i dump EEPROM from NIC that used I350, then mod this dumped data, then apply to our board?
Thanks!
Josue_C_Intel
Hi Heeseob Jung
Referring to Section 3.3.1.4 Software Accesses:
"The I350 provides two different methods for software access to the EEPROM. It can either use the builtin controller to read the EEPROM or access the EEPROM directly using the EEPROM's 4-wire interface…
Software can also directly access the EEPROM's 4-wire interface through the EEPROM/Flash Control
(EEC) register. It can use this for reads, writes, or other EEPROM operations."
To directly access the EEPROM, software should follow these steps:
1. Take ownership of the EEPROM Semaphore bit as described in Section 4.7.1.
2. Write a 1b to the EEPROM Request bit (EEC.EE_REQ).
3. Poll the EEPROM Grant bit (EEC.EE_GNT) until it becomes 1b. It remains 0b as long as the
hardware is accessing the EEPROM.
4. Write or read the EEPROM using the direct access to the 4-wire interface as defined in the EEPROM/
Flash Control and Data (EEC) register. The exact protocol used depends on the EEPROM placed on
the board and can be found in the appropriate datasheet.
5. Write a 0b to the EEPROM Request bit (EEC.EE_REQ) to enable EEPROM access by other drivers.
We are going to upload the document # 474233 Intel® Ethernet Controller I350 [Powerville] – EEPROM Images – Rev. 1.63, and we will let you know as soon as the document is available.
Best Regards.
Josue.
Josue_C_Intel
Hello Heeseob Jung.
Welcome to Intel® Embedded Community.
We are checking your thread and will post an update as soon as possible.
Regards.
Josue.
Josue_C_Intel
Hi Heeseob Jung.
According to https://www-ssl.intel.com/content/www/us/en/ethernet-controllers/ethernet-controller-i350-datasheet.html Intel® Ethernet Controller I350 Datasheet there are some features that only can be configured from EEPROM, for example section 3.2.1.1 Channel Behavior:
"SMBus connection speed bits define the SMBus mode. Also, SMBus frequency support can be defined only from the EEPROM."
We still working in the others questions, we will let you know as soon as possible, please stay tuned.
Best Regards. Josue.
HJung8
Josue_C_Intel
Hi Heeseob Jung
Best Regards.
Josue.
Natalie_Z_Intel
474233 is an Intel confidential document but it looks like you will be all set to access it once it is posted. JC will let you know when it is ready. I hope you are having an nice weekend! LynnZ
Josue_C_Intel
Hello Heeseob Jung
Doc https://www-ssl.intel.com/content/www/us/en/secure/embedded/nda/products/networking/ethernet-controller-i350-eeprom-images.html # 474233 Intel® Ethernet Controller I350 [Powerville] – EEPROM Images – Rev. 1.63 is now available in EDC Library.
Please let us know if you need further information.
Josue.
HJung8
How nice! Thanks for support.
I will check on our board.
PHütt
we are using the I350 on our design. Is their a software(linux) where we are able to programm the eeprom images incircuit.
Peter
Josue_C_Intel
Hello Peter,
We are working in your question, as soon as we have updates we will let you know.
Best Regards.
Josue.
Hello Peter Hütt,
Here is a link where you could download a Linux software to program EEPROM.
Though this content can only be accessed with a Privileged Account.
https://www-ssl.intel.com/content/www/us/en/secure/intelligent-systems/privileged/quartzville-tools-284632.html?wapkw=quartzville Intel® Network Connections Tools
Leon
Natalie_Z_Intel
Hi, Peter! It looks like you are all set to be able to access this file. It is a zip file which takes some time to download . Have a nice day! LynnZ.
HJung8
Hi!
Thanks for update. This is what need for us too.
But this package contains x86/amd64 binaries only...
I was making eeprom update program based on datasheet's description, but that was difficult and have no time to complete.
Could i get celo/eeupdate/lanconf/... binaries for arm architectures?
Sorry to ask this now.
Thanks. Have a nice day!
Gabriel_T_Intel
Hello Heeseob,
I will be sending you the file eepromARMTool_0.6.7.zip,
Please confirm If you receive the email.
Gabriel Thomas
HJung8
Hello!
I've received eepromARMTool_0.6.7.zip.
But this program seems not supporting i350..
root@ubuntu-armhf:~# lspci
00:00.0 PCI bridge: Device 16c3:abcd (rev 01)
01:00.0 Ethernet controller: Intel Corporation Device 151f (rev 01)
01:00.1 Ethernet controller: Intel Corporation Device 151f (rev 01)
root@ubuntu-armhf:~# lspci -n
00:00.0 0604: 16c3:abcd (rev 01)
01:00.0 0200: 8086:151f (rev 01)
01:00.1 0200: 8086:151f (rev 01)
root@ubuntu-armhf:~# ./eepromARMtool
Intel(R) Eeprom ARM Tool ARM OTP Programming Tool
Provided under the terms of a CNDA. Do Not Distribute.
Copyright(C) 2013 by Intel(R) Corporation
NIC BUS DEV FUN Silicon Memory Type Present
No result at all.
No result for i350 product ids.
[05-22 10:55:42][hsjung] eepromarmtool $ grep -ir 151[0-9]
[05-22 10:55:46][hsjung] eepromarmtool $ grep -ir 151f
[05-22 10:55:48][hsjung] eepromarmtool $
Thanks!
Josue_C_Intel
Hello Heeseob,
We are working on this case, we will let you know as soon as we have any update.
Best Regards.
Josue.
Josue_C_Intel
Hello Heeseob,
Currently, there is not a tool specifically for I350.
If you want to modify the eepromarmtool source code to add support for I350, you are free to do it, it is needed to add extra information such as the device id and verify that the pcie registers are correctly defined. However Intel has no validated this kind of modifications, so it should be validated by your own.
Best Regards.
Josue.
RFili
is a similar problem, if I can get the file eepromARMTool_0.6.7.zip?
CarlosAM_INTEL
Hello eepromARMTool_0.6.7.zip,
Thank you for contacting the Intel Embedded Community.
The information you seek is classified as Intel confidential, which requires a CDNA between your company and Intel as well as a Privileged EDC account.
Please let us know as soon as your Privileged account update will be approved.
Thanks in advance for your cooperation.
Carlos_A.
AFade
Hello gabriel.thomas Could you also send ARM tool to me?
CarlosAM_INTEL
Hello AlexandrFadeev,
We will contact you via email to help you.
Carlos_A.
