Ethernet Products
5821 Discussions
cards are shutting down if I execute dpdk-devbind.py
LokeshChakka
The moment I enabled DPDK, Network card is going down.
$ lspci | grep -i intel
c3:00.0 Ethernet controller: Intel Corporation Ethernet Controller E810-C for QSFP (rev 02)
c3:00.1 Ethernet controller: Intel Corporation Ethernet Controller E810-C for QSFP (rev 02)
$ sudo dpdk-devbind.py -b vfio-pci c3:00.0 c3:00.1
After this, cards are going down. EAL is giving error
EAL: Requested device 0000:c3:00.1 cannot be used
EAL: Error - exiting with code: 1
Cause: Error: number of ports must be even
I am seeing cards are shutting down because the green LED is no more glowing after running devbind
Mike_Intel
Hello LokeshChakka,
Since this question involves DPDK, please check with Intel Premier Support for further assistance. See the following for access to Intel Premier Support.
Click the "Access and Log In" to contact the DPDK support
https://www.intel.com/content/www/us/en/design/support/ips/training/welcome.html
Please be informed that we will now close this request. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
May you have a great day!
Thank you.
Michael L.
Intel® Customer Support
