- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Hi
I am trying SRIOV NIC on my computer(intel X540-T2)
everything is fine, I can see VF and PF in PCI list but when I assigned 1 VF to 1 VM and then boot it, I got an error message
here is the message
Internal error: process exited while connecting to monitor: 2017-04-11T04:32:00.179452Z qemu-kvm: -device vfio-pci,host=02:10.0,id=hostdev0,bus=pci.0,addr=0x3: vfio: error, group 1 is not viable, please ensure all devices within the iommu_group are bound to their vfio bus driver. 2017-04-11T04:32:00.179495Z qemu-kvm: -device vfio-pci,host=02:10.0,id=hostdev0,bus=pci.0,addr=0x3: vfio: failed to get group 1 2017-04-11T04:32:00.179502Z qemu-kvm: -device vfio-pci,host=02:10.0,id=hostdev0,bus=pci.0,addr=0x3: Device initialization failed. 2017-04-11T04:32:00.179511Z qemu-kvm: -device vfio-pci,host=02:10.0,id=hostdev0,bus=pci.0,addr=0x3: Device 'vfio-pci' could not be initialized Traceback (most recent call last): File "/usr/share/virt-manager/virtManager/asyncjob.py", line 88, in cb_wrapper callback(asyncjob, *args, **kwargs) File "/usr/share/virt-manager/virtManager/asyncjob.py", line 124, in tmpcb callback(*args, **kwargs) File "/usr/share/virt-manager/virtManager/libvirtobject.py", line 83, in newfn ret = fn(self, *args, **kwargs) File "/usr/share/virt-manager/virtManager/domain.py", line 1404, in startup self._backend.create() File "/usr/lib64/python2.7/site-packages/libvirt.py", line 1035, in create if ret == -1: raise libvirtError ('virDomainCreate() failed', dom=self) libvirtError: internal error: process exited while connecting to monitor: 2017-04-11T04:32:00.179452Z qemu-kvm: -device vfio-pci,host=02:10.0,id=hostdev0,bus=pci.0,addr=0x3: vfio: error, group 1 is not viable, please ensure all devices within the iommu_group are bound to their vfio bus driver. 2017-04-11T04:32:00.179495Z qemu-kvm: -device vfio-pci,host=02:10.0,id=hostdev0,bus=pci.0,addr=0x3: vfio: failed to get group 1 2017-04-11T04:32:00.179502Z qemu-kvm: -device vfio-pci,host=02:10.0,id=hostdev0,bus=pci.0,addr=0x3: Device initialization failed. 2017-04-11T04:32:00.179511Z qemu-kvm: -device vfio-pci,host=02:10.0,id=hostdev0,bus=pci.0,addr=0x3: Device 'vfio-pci' could not be initialized
I think the reason is all of the VF and PF devices are in the same iommu_group and I found they are really in the same iommu_group after I check that.
It seems that all devices in same iommu_group should be assigned to 1 VM, if not, it will cause an error.
However I need to assign each VF to different VM.
Now I temporary move the NIC to a server and the problem is gone but because of some reason I prefer to use this NIC on my original computer.
Does this have solution? thanks a lot.
My environment :
Host OS : RHEL 7.3 Kernel Version 3.10.0-514.10.2.el7.x86_64
GNOME 3.14.2
CPU: I7-6700
MB:ASUS Q170
PF driver : ixgbe 5.0.4
kernel command line : intel_iommu=on pci=realloc pci=assign-busses
VM OS : fedora 25
VF driver : ixgbevf 4.0.3
- Marcas:
- Devices
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi w180112,
Thank you for the post. Please check if your board supports VT-D and SR-IOV. It is recommended to use server board that supports VT-D and SR-IOV.
wb
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi w180112,
wb
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi wb
thanks for the reply
I have set VT-d and VT-x enable in bios.
So it's no solution unless I change the environment to a server right?
thanks
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi w180112,
Thank you for the reply. Let me further check.
rgds,
wb
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi w180112,
Yes. You need to use server board that supports VT-D and SR-IOV. Hope this clarified.
Rgds,
wb
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi W180112,
Please feel free to update if further clarification needed. Thanks.
Rgds,
wb
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
sorry for late reply
I am sure that VT-D and VT-x is enable and iommu is on
however I still got error :(
maybe i should give up for using this card on my original PC?
thanks
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
HI W180112,
You need to use a server board that supports VT-D and SR-IOV. Thank you.
Rgds,
wb
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
