Ethernet Products
5314 Discussions
errors on traffic received to E810 port
PCohen
Hi
I have a program listening for traffic on a one of the ports on the E810(quad-port).
There are occasionally errors when reading from the file descriptor bound to this interface. (POLLERR)
When traffic is slightly higher, the errors occur very often - resulting in very high CPU usage.
I do not have this issue with other controllers such as X710-DA2 and 82599ES.
extra details:
ethtool -i output:
driver: ice
version: 1.11.14
firmware-version: 4.20 0x80017789 1.3346.0
expansion-rom-version:
bus-info: 0000:1b:00.3
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
lspci output:
1b:00.0 Ethernet controller: Intel Corporation Ethernet Controller E810-C for SFP (rev 02)
1b:00.1 Ethernet controller: Intel Corporation Ethernet Controller E810-C for SFP (rev 02)
1b:00.2 Ethernet controller: Intel Corporation Ethernet Controller E810-C for SFP (rev 02)
1b:00.3 Ethernet controller: Intel Corporation Ethernet Controller E810-C for SFP (rev 02)
CPU: Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz
OS: CentOS Linux 7 (under VMWare ESXi)
Irwan_Intel
Hi PCohen
In order for us to further check and investigate the issue, please provide the following details.
1. Please provides serial number and PBA number of the NIC Card or picture on both sides focusing on the markings for us to validate if the unit is an OEM unit or not.
2. What is the brand and model of your board or system?
3. Kernel version of Centos 7?
Please let us know if you have a questions. In case we do not hear from you, we will follow up within 3 business days.
Irwan_Intel
Intel® Customer Support
PCohen
Hi Irwan_Intel,
I added the details you requested and I am waiting for your response, please advise.
Regards, PCohen
PCohen
Hi Irwan_Intel, thank you for your reply.
1. These are the numbers I found on the card(attaching the not very clear pictures):
Intel(R) Eth Network Adapter E810 - XXVDA4T
99AD9D
E810XXVDA4TG1
Manufactured 01/2023
507C6F4ACFF4
004 0223AD
M56952 - 004
2. Product Name: ProLiant ML350 Gen10 (Server has 2 CPU's)
    Server Serial Number: CZJ2511MLH
    Product ID: P21788-421
attaching snip of other details
3. kernel version 3.10.0-1160.88.1.el7.x86_64
Regards, PCohen
Irwan_Intel
Hi PCohen,
Thank you for providing the additional details. I am currently reviewing the information with our next level.
I will get back to you as soon as possible with my response. Thank you for your patience.
Irwan_Intel
