Ethernet Products
5717 Discussions
i210 EEPROM contents: CopperTP vs. FIBRE
LFelt
Hello intel,
I've got an EEPROM attached to an i.MX6 via PCIe. I can program the EEPROM over PCIe and then the i210 reports the correct PCI VID:PID of 8086:1533.
ethtool reports:
# ethtool enp1s0
Settings for enp1s0:
Supported ports: [ FIBRE ]
Supported link modes: 100baseT/Full
1000baseT/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: Yes
Advertised link modes: Not reported
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Speed: Unknown!
Duplex: Unknown! (255)
Port: FIBRE
PHYAD: 0
Transceiver: external
Auto-negotiation: on
Supports Wake-on: pumbg
Wake-on: g
Current message level: 0x00000007 (7)
drv probe link
Link detected: no
But I'd like to use the TP port, not fibre.
Does this depend only on the EEPROM contents?
Where can I get the EEPROM contents configured for a plain i210 twisted pair (copper) port?
Lo
Hi Lo,
Thank you for the post. I will check for you about the eeprom contents, will update you once there is any finding.
rgds,
wb
Hi Lo,
Further checking, you need to contact your field application engineer and also need a NDA (Non disclosure agreement) for support. Please try contacting your FAE or the point of purchase where you got the i210.
wb
Hi Lo,
Have you contacted the field application engineer for further assistance?
wb
LFelt
Hi wb,
thanks for your reply. The project volume is too low for intel to go though the hassle for a CNDA, so I didn't get any futher information from intel.
I found the cause myself: the EMS mounted a wrong type of i210, there are at least two different i210 types: one for TP and one for FIBRE.
If someone else needs to look it up: The data sheet does not explain package markings but the errata does.
Lo2
Hi Lo,
Thank you for the update and the clarification. I am glad that you manage to find the cause and fix the issue. Can you share me the link about the errata you mentioned.
wb
LFelt
Hi wb,
here's the link to intels errata document for the i210:
http://www.intel.de/content/www/de/de/embedded/products/networking/i210-ethernet-controller-spec-update.html Intel® Ethernet Controller I210: Specification Update
package markings -> see chapter 1.2 Marking Diagrams.
Lo
Hi Lo,
Thank you for sharing the information.
rgds,
wb
