Ethernet Products
5782 Discussions
i210 Flash interface
SMani3
The i210 datasheet recommends to use certain flash devices. However their sizes are 512KB on wards only. There is mention in the datasheet that maximum of 8MB is supported.
I would like to know if lower memory sizes (128KB, 256KB) are supported or not.
Hi Sathmmaa4,
Thank you for posting in Wired Communities. Please post your inquiry at our embedded support for them to better assist you with the inquiry.
http://embedded.communities.intel.com/
Sharon T
