Ethernet Products
4350 Discussions
i354 LLDP packets not received
CVasi
I have a Linux station with an Intel i354 ethernet controller. I'm trying to use LLDP for discovery between these stations, but it does not seem to work. If I use other interfaces, with different NICs, the LLDP utilities work ok. Could someone give me some hints on what might be wrong?
Hi CatalinV,
Thank you for posting in Wired Ethernet Communities.
Please share additional information regarding your setup:
1. Ethtool -i output of your Intel Ethernet controller
2. LLDP utility used
3. Brand and model of other NIC without the issue
4. Linux distribution and kernel version
regards,
Vince
Hi CatalinV,
We'd like to follow-up the requested information. Thanks.
regards,
Vince
CVasi
I've done some more research on my scenario, and there was another mid device that actually filtered those LLDP packets.
Sorry, my bad. There is nothing wrong with i354 when it comes to LLDP.
