Ethernet Products
5821 Discussions
intel QV driver: eeupdate or lanconf is not able connect to the QV driver
KDutt
The eeupdate and the lanconf tool is not working. These tools need the IQV driver. However once I load the latest driver, these tools errors out with the following messages:
Connection to QV driver failed - please reinstall it!
This output is with the older iqv driver version: 1.1.4.17
[root@xrsdev29 ~]# ./lanconf64e /VERSION
Using: Intel (R) PRO Network Connections SDK v2.28.29
LANConf v1.28.29.03
Intel(R) Diagnostic Tool for PRO Series Ethernet adapters
Copyright (C) 2006 - 2017 - 2017 by Intel (R) Corporation. All rights reserved.
Intel (R) Confidential and not for general distribution.
[root@xrsdev29 ~]#
Now, if I run the older tool, it does not complain. However, in both these cases the lanconf tool should have complained, as the iqv driver is not loaded in either of these cases.
root@xrsdev29 ~]# ./STX_3PF_UTIL_106/util/intel/lanconf /VERSION
Using: Intel (R) PRO Network Connections SDK v2.24.33
LANConf v1.24.33.07
Copyright (C) 2006 - 2015 by Intel (R) Corporation. All rights reserved.
[root@xrsdev29 ~]# lsmod |grep iqv
[root@xrsdev29 ~]#
After I load the iqv driver (latest):
[root@xrsdev29 ~]# modprobe iqv
[root@xrsdev29 ~]# modinfo iqv
filename: /lib/modules/3.10.0-327.36.3.el7.0.1.63.xl7.x86_64/weak-updates/iqv/iqv.ko
version: 1.2.0.4
license: GPL
description: 1.2.0.4
author: Intel Corporation
rhelversion: 7.2
srcversion: EBD18E94CC97F7B1A7F08EF
depends:
vermagic: 3.10.0-327.28.2.el7.0.1.29.xl7.x86_64 SMP mod_unload modversions
[root@xrsdev29 ~]#
[root@xrsdev29 ~]# ./STX_3PF_UTIL_106/util/intel/lanconf /VERSION <----- older lanconf tool, so expected output.<p>
Driver version do not match, please reinstall driver
[root@xrsdev29 ~]# ./lanconf64e /VERSION <------- New lanconf tool came with iqv driver. It still complains after loading the iqv driver
LANConf v1.28.29.03
[root@xrsdev29 ~]#
So, why the latest IQV driver does not work with the latest eeupdate and lanconf tools, whereas older driver with older tools works!
Kongkon
