Ethernet Products
5761 Discussions
intel nic drivers 19.3 huge 6000+ dpc latency spike once a few secs
ATay3
140 759 Visites
hi, i would like to report that the new intel nic drivers version 19.3 that just released recently has huge 6000+ dpc latency spike once in a few secs.
my specs
Intel(R) 82579LM Gigabit Network Connection
windows 7 SP1 32bit + lastest windows update
i downgrade to intel nic drivers previous version 19.1 and the problem is just gone.
285 Réponses
vioni
5 481 Visites
I gave up and went back to windows 8.1, using 18.5 driver suite.
while there are some time to time spikes of ndis.sys they don't create any stutter on windows 8.1
0 Compliments
PLee27
5 481 Visites
Windows 8.1 pro x64 here installed 20.4.1 driver with absolutely no any spikes anymore here...
0 Compliments
vioni
5 481 Visites
do you use torrent clients?
I still got some spikes even on windows 8.1, but no mini-freezes or stutters like on windows 10.
0 Compliments
PLee27
5 481 Visites
Yup, with the latest version of utorrent
0 Compliments
st4
Nouveau contributeur III
5 592 Visites
Hi Cel
Further checking and testing, we were not able to reproduce the issue. With regards to the latencyMon result,
this might not be related to I219V since NDIS.sys has nothing to do with the I219V driver.
Please contact your motherboard vendor for further investigation.
rgds,
wb
0 Compliments
CX
Débutant
5 592 Visites
So im guessing its a pure coincidence then that if i switch off network adapter the issue disappears or the fact that people have been discussing ndis.sys driver since 2014, or the fact that i've contacted Asus support 3 times and each time they told me that this is an Intel's issue and got this response last time:
Greetings!
Thank you for contacting Asus technical support.
Yes we know about that problem and also we know that it relates to the specifics of this ethernet adapter and it's programming code. All of this relates and being developed by a third party company - Intel. Because of this even if there is ever a solution - it can only be provided by Intel and no BIOS settings will be able to fix that issue.
There are no known solutions to this problem on our side since there are no settings (including BIOS settings) which can somehow fix or influence an ethernet adapter. If there were any driver or BIOS settings to fix this issue - we would've expected Intel to provide them already.
Since this issue appeared only on the resent OS - it is related to software programming and will probably be fixed later. Meanwhile you can buy a cheaper discrete network card and use it instead.
Also - what about tcpip.sys? This issue appears every single day since i bought my pc, even on clean installation of windows. It starts slowly then progresses to huge lag spikes of both tcpip.sys and ndis.sys.
0 Compliments
PLee27
5 592 Visites
Well.... it seems like Intel know shifting off so much......
0 Compliments
vioni
5 592 Visites
if you wouldn't refuse the do the proper tests using lame excuses you will be able to reproduce it in less than half of hour.
meanwhile you pretend to checking further on the issue for years.
whith sales so high and so much money we are bringing into your company...I would never pick intel as unserious company with such poor driver support.
and to think I bought my motherboard to specificaly have an integrated intel NIC. won't make that mistake again...
0 Compliments
CX
Débutant
5 592 Visites
I wrote to Asus support again and this is the answer i've got:
Greetings!
Our engineers are still certain that the problem exists on the Intel's side and perhaps partially on the Microsoft side as well, and this is completely logical since this issue does not appear on Windows 7 or 8/8.1 in our testing labs but it does appear on Windows 10 while using same testing methods. This means that this issue is probably not hardware related (though it could be related to the constructive problems of a microchip of the ethernet controller), so the issue seems to be unrelated to a manufacturer of the motherboard.
Asus company cares for its costumers and when we find clear issues with our products we are always doing everything we can to fix them if its in our powers. Unfortunately in this case there is nothing we can do to fix this.
Again - i've translated it to English almost word for word.
Just to be clear - i do not defend Asus company but in this particular case i trust them more than i do the guy who's claiming to be from Intel. Either they did the testing wrong or used wrong drivers, wrong windows version or did not wait long enough/used internet long enough for the issue to appear. Sometimes it takes some hours, sometimes it appears immediately.
Also i've just spent several hours testing ethernet adapter and i can confirm that switching it off fixes this issue. Enabling it again causes immediate huge latency spike in ndis.sys driver, as well as sound stuttering.
So the idea that ndis.sys (network driver interface specification) is unrelated to 219v driver is completely incorrect.
Just to reiterate:
1) Asus confirmed again that this issue happens on Windows 10 (possibly x64 or both) systems and it is related to Intel's software, or less plausibly - to Intel's hardware (microchip).
2) NDIS.sys IS in fact related to I219V driver as switching ethernet adapter on and off causes immediate latency spikes even on a clean system installation.
3) Issue seems to be appearing gradually and in 12-15 hours every single opened page or download causes latency spikes with NDIS.sys (over 8k) as well as "interrupt to process latency" spikes over 20k and 10-30ms execution time delays.
0 Compliments
RM61
Débutant
5 592 Visites
Same here. Using Asus P8Z77-V with Intel 82579V. Huge DPC spikes with sound crackle on Windows 10. Every 15-30 minutes system freezes for ~0.5 seconds.
Switching to integrated Atheros wi-fi and disabling intel card fixes the issue. But wi-fi isn't good for online gaming. So, broken driver forced me to downgrade to Windows 8.1.
This huge issue needs to be fixed fast.
0 Compliments
vioni
5 521 Visites
i have tryed every single driver there is available for windows 10 x64 for my integrated i218-V... nothing
when i open a torrent client dpc latency goes thru the roof.
0 Compliments
st4
5 521 Visites
Hi apoklyps3,
Understand you tried several drivers, just to double check if you have tried the driver 20.4.1 at
https://downloadcenter.intel.com/download/25016/Network-Adapter-Driver-for-Windows-10 Download Network Adapter Driver for Windows® 10
rgds,
wb
0 Compliments
vioni
5 521 Visites
yes. nothing changed.
don't guys test these yourselves? it takes less than 5 minutes to do so
0 Compliments
Ddomi1
Débutant
5 481 Visites
hi, just decided to register so i can reply as well since i read this topic since september. i have the same issue.
Asrock h97 pro4 on windows 10
tryied with all the kind of driver without any results. of course i started with the asrock website 1st.
a software that can increase DPC ? team speak, just logging in into a server without talk or listen anyone talking dpc goes high.
0 Compliments
YMast
Débutant
5 481 Visites
same here, but AGAIN !
strange thing is that i resolve this issue when i disable Intel EIST (speedstep) on my mobo. and that was fine couple month until i decide to install software for mobo which control fans in case (probably because app. working changes direct in bios and switch some settings).
After that i again have constant latency around ~1000
latencymon telling it`s ndis.sys issue...
I really don`t know what can be anymore, because i try many options and lose many hours on this, but i/we need solution for this, computer is not fully useful with this issue...
conf. is:
Windows 10 Pro 64-bit
Intel Core i7 4771
Asus MAXIMUS VI HERO
ASUS Xonar Essence STX Audio Device
0 Compliments
YMast
Débutant
5 481 Visites
Interesting, seems that this is not NIC related..
I successful resolve issue again with turning off on mobo all parts about power saver, c state, voltage controller and similar automatic stuff which mobo have.
So, for all, try to disable ALL automatic stuff in bios... experiment with turning off/on options.. i bet you will resolve dpc latency issue.
But what now? seems that this is only applied on intel CPU ? is there AMD users with this issue?
0 Compliments
CX
Débutant
5 481 Visites
Every single motherboard is different. I've got more than a hundred settings in my UEFI bios and i barely know what a third of them does.
Messing around in bios on a bet that it MIGHT help is not a solution.
0 Compliments
YMast
Débutant
5 481 Visites
not MIGHT, IT WILL! just try, take your mobo manual book and search for power saver features and try with disable, i bet you will solve the issue.
But where is the problem is really good question... intel should work on this and find answer!
Here is my dpc latency after disable all mobo features about power saving:
https://www.dropbox.com/s/tzhbdx09z5be85v/latency.PNG?dl=0 https://www.dropbox.com/s/tzhbdx09z5be85v/latency.PNG?dl=0
i still have biggest latency by NIC card, but issue with video/games/audio are gone after turning off those options...
p.s: i was have latency around 1000 !!
0 Compliments
vioni
5 481 Visites
no torrent client running = not relevant.
0 Compliments
CX
Débutant
5 481 Visites
Well i've tried disabling several different bios settings which could've been related to network, cpu or ram - nothing worked.
I can also confirm that the longer your pc is switched on - the worse the issue gets. After i just switch on the pc i get an occasional lag spike when im downloading something big or watch a youtube video and download something. After 8 or so hours it gets worse and simply refreshing the browser page causes huge lag spike with ndis.sys driver.
0 Compliments
YMast
Débutant
5 481 Visites
which mobo you have?
0 Compliments
Répondre
