Hi, I have an XL710-QDA2 running on Ubuntu 22.04 (HWE kernel, 6.2.0-35-generic) using the default Linux i40e driver.
The NIC was running a very old firmware version (4.24 0x800013fc 0.0.0 as indicated by ethtool) so I tried upgrading to the latest version 9.30 using the nvmupdate64e (downloaded from [1]). The upgrade ended with an error and since then the NIC is unusable and running the tool again shows Access Error.
# ./nvmupdate64e
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.39.56.8
Copyright(C) 2013 - 2023 Intel Corporation.
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [*.........]
Num Description Ver.(hex) DevId S:B Status
01) Intel(R) Ethernet Converged N/A(N/A) 1583 00:007 Access error
Network Adapter XL710-Q2
Tool execution completed with the following status: Device not found.
Press any key to exit.
I tried rolling back the firmware using the -r and -m flags and the backup image created by the upgrade tool, but without luck so far.
# ls 6805CA306848/
6805CA306848.bin 6805CA306848.flb
# ./nvmupdate64e -r -m 6805CA306848
# echo $?
19
According to [2] and [3], I have an Intel card, not an OEM, as the Vendor/Device ID matches the XL710QDA2 ID from [2].
# lspci -nn | grep XL710
07:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller XL710 for 40GbE QSFP+ [8086:1583] (rev 01)
07:00.1 Ethernet controller [0200]: Intel Corporation Ethernet Controller XL710 for 40GbE QSFP+ [8086:1583] (rev 01)
Is there any hope to recover this NIC? How can I rollback the original firmware or install a newer one? Thanks in advance.
Further info:
Driver messages on kernel logs:
# dmesg | grep i40e
[ 8.010328] i40e: Intel(R) Ethernet Connection XL710 Network Driver
[ 8.043618] i40e: Copyright (c) 2013 - 2019 Intel Corporation.
[ 20.516125] i40e 0000:07:00.0: PF reset failed: -15
[ 20.516837] i40e 0000:07:00.0: Entering recovery mode due to repeated FW resets. This may take several minutes. Refer to the Intel(R) Ethernet Adapters and Devices User Guide.
[ 20.521852] i40e: probe of 0000:07:00.0 failed with error -15
[ 32.180003] i40e 0000:07:00.1: PF reset failed: -15
[ 32.180838] i40e 0000:07:00.1: Entering recovery mode due to repeated FW resets. This may take several minutes. Refer to the Intel(R) Ethernet Adapters and Devices User Guide.
[ 32.185692] i40e: probe of 0000:07:00.1 failed with error -15
Output of lspci:
# lspci -vvv -d 8086:1583
[157428.273296] pci 0000:07:00.0: VPD access failed. This is likely a firmware bug on this device. Contact the card vendor for a firmware update
07:00.0 Ethernet controller: Intel Corporation Ethernet Controller XL710 for 40GbE QSFP+ (rev 01)
Subsystem: Intel Corporation Ethernet Converged Network Adapter XL710-Q2
Physical Slot: 2
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 135
NUMA node: 0
Region 0: Memory at f5000000 (64-bit, prefetchable) [size=8M]
Region 3: Memory at f6800000 (64-bit, prefetchable) [size=32K]
Expansion ROM at f2100000 [virtual] [disabled] [size=512K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [70] MSI-X: Enable- Count=129 Masked-
Vector table: BAR=3 offset=00000000
:[157428.409293] pci 0000:07:00.0: VPD access failed. This is likely a firmware bug on this device. Contact the card vendor for a firmware update
PBA: BAR=3 offset=00001000
Capabilities: [a0] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 2048 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
DevCtl: CorrErr- NonFatalErr+ FatalErr+ UnsupReq-
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop- FLReset-
MaxPayload 256 bytes, MaxReadReq 4096 bytes
DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr- TransPend-
LnkCap: Port #0, Speed 8GT/s, Width x8, ASPM L1, Exit Latency L1 <16us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s (ok), Width x8 (ok)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR-
10BitTagComp- 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
ductionInit-
FRS- TPHComp- ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR- OBFF Disabled,
AtomicOpsCtl: ReqEn-
LnkCap2: Supported Link Speeds: 2.5-8GT/s, Crosslink- Retimer- 2Retimers- DRS-
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+ EqualizationPhase1+
EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-
Retimer- 2Retimers- CrosslinkRes: unsupported
Capabilities: [e0] Vital Product Data
Not readable
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq+ ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq+ ACSViol-
UESvrt: DLP- SDES+ TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
Capabilities: [140 v1] Device Serial Number 48-68-30-ff-ff-ca-05-68
Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 1
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [160 v1] Single Root I/O Virtualization (SR-IOV)
IOVCap: Migration-, Interrupt Message Number: 000
IOVCtl: Enable- Migration- Interrupt- MSE- ARIHierarchy+
IOVSta: Migration-
Initial VFs: 64, Total VFs: 64, Number of VFs: 0, Function Dependency Link: 00
VF offset: 16, stride: 1, Device ID: 154c
Supported Page Size: 00000553, System Page Size: 00000001
[157534.633351] pci 0000:07:00.0: VPD access failed. This is likely a firmware bug on this device. Contact the card vendor for a firmware update
Region 0: Memory at 00000000f6000000 (64-bit, prefetchable)
Region 3: Memory at 00000000f6810000 (64-bit, prefetchable)
VF Migration: offset: 00000000, BIR: 0
Capabilities: [1a0 v1] Transaction Processing Hints
Device specific mode supported
No steering table available
Capabilities: [1b0 v1] Access Control Services
ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
Capabilities: [1d0 v1] Secondary PCI Express
LnkCtl3: LnkEquIntrruptEn- PerformEqu-
LaneErrStat: 0
Kernel modules: i40e
07:00.1 Ethernet controller: Intel Corporation Ethernet Controller XL710 for 40GbE QSFP+ (rev 01)
Physical Slot: 2
NUMA node: 0
Region 0: Memory at f5800000 (64-bit, prefetchable) [size=8M]
Region 3: Memory at f6808000 (64-bit, prefetchable) [size=32K]
Expansion ROM at f2180000 [virtual] [disabled] [size=512K]
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1-
EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
Not readable
ARICap: MFVC- ACS-, Next Function: 0
IOVCtl: Enable- Migration- Interrupt- MSE- ARIHierarchy-
IOVSta: Migration-
Initial VFs: 64, Total VFs: 64, Number of VFs: 0, Function Dependency Link: 01
VF offset: 79, stride: 1, Device ID: 154c
Region 0: Memory at 00000000f6400000 (64-bit, prefetchable)
Region 3: Memory at 00000000f6910000 (64-bit, prefetchable)
Hello mscastanho,
Greetings for the day!
Thank you for contacting Intel Customer Support.
We do understand that your Ethernet XL710-QDA2 having trouble to update the firmware.
Since you have tried several steps with unsuccessful, you would need to update the correct version of the firmware.
Below is the link for you to follow step by step to ensure the updating process is correct with driver version as well.
Link: https://www.intel.com/content/www/us/en/support/articles/000030492/ethernet-products.html
Updating the firmware could cause damage to the card if the wrong firmware is applied.
Please do let us know if once you tried.
Yogaeasvaran
Hi @Yogaeasvaran ,
Those are actually the steps I followed in the first place during the update that caused the issue. I tried again:
- Downloaded NVM update utility version 9.30
- Copied the Linux version to the server
- Ran nvmupdate64e
But the issue is the same:
# ./nvmupdate64e
Should I use an specific version of the NVM update utility considering that I was using 4.24 before the failed upgrade?
Hello mscastanho,
Thank you for response.
Yes, you may try update to update to the version before failed and check.
Please do let us know if once you tried as we may isolate this further.
Yogaeasvaran
I was unable to find the 4.24 version for download at [1], so I tried with version 4.42. The error is slightly different now, but still no success.
# ./nvmupdate64e
NVMUpdate version 1.24.33.08
Copyright (C) 2013 - 2015 Intel Corporation.
WARNING: TO AVOID DAMAGE TO YOUR DEVICE, DO NOT EXIT OR REBOOT OR POWER OFF THE SYSTEM DURING THIS UPDATE
Inventory in progress. Please wait [*-........]
Num Description Device-Id B:D Adapter Status
01) Intel(R) Ethernet Converged Network Ad 8086-1583 07:00 Access error
Tool execution completed with the following status: Communication with base driver failed. Please verify that the base driver is present
Thank you for your response.
You have tried to update the firmware but unsuccessful and not able to be solved upon trying the steps I've given.
Could you please provide me the SSU log to isolate this issue further.
Please follow the guide from below link:
Help Guide for the Intel® System Support Utility
Yogaeasvaran
The SSU log is attached.
There were also some error messages when I ran the script:
# ./ssu.sh
This product is not supported on this operating system.
Would you like to try to scan? (y/n)
y
/bin/cat: /sys/devices/virtual/dmi/id/board_vendor: No such file or directory
Cannot get driver information: No such device
We are checking this issue and will get back you the soonest.
Yogaeasvaran
Thank you for your patience.
Could you please provide us NIC PBA/Part number and share a picture of the NIC. Also, please verify the place of purchase for the NIC.
Yogaeasvaran
I'm trying to find a way to take a picture of the NIC, since this is a remote server. I'll get back to you as soon as possible.
But I also share part of the sentiment of the previous comment, most of the similar threads I found follow the same pattern.
Let's hope there's a solution for this one.
Was Intel able to fix this issue, it seems like every post that has the same issue gets the same response.
"Send a picture and that's not a recognized Intel adapter!"
Do issues actually get fixed??
This can't be impossible. It's a failed update, that should have a work around after Intel's utility fails, are they just trying to sell more cards?
Thank you for your feedback and we will wait for the Picture and details from you.
Yogaeasvaran
Greetings,
Thank your feedback with details.
We will check with our engineering team to isolate further and will get back you the soonest.
Yogaeasvaran
Greetings,
Thank you for the patience.
As per our engineering team advice, the Feature Support matrix shows that it is necessary to update to 4.42 before going to higher versions.
https://www.intel.com/content/www/us/en/support/articles/000093197/ethernet-products.html
Please try to perform recovery state following the link:
https://www.intel.com/content/www/us/en/support/articles/000089896/ethernet-products.html
We also share the Quick usage for your guidance.
https://www.intel.com/content/www/us/en/support/articles/000088453/ethernet-products.html
Please do ket us know if need anything else.
Yogaeasvaran
So according to the recovery guide I need to run the NVM Update tool to get things fixed, but doesn't it make we go back to square 1? Since the update tool is not working properly anymore with the card.
As I mentioned previously, I also tried to use the NVM Update tool version 4.42, but it failed with the following message:
Looks like the tool is not working properly with the upstream Linux i40e driver that is installed in the machine.
So I'm trying to install the i40e driver from Intel, version 1.2.37, which according to the support matrix is compatible with the 4.42 firmware version.
I'll update the thread when I get more info.
Greetings,
Thank you for the feedback.
We will be waiting for your update.
Yogaeasvaran
Greetings,
We would like to follow up if you able to get details could you please let us know when you can be able to provide feedback.
Yogaeasvaran
Greetings,
We would like to follow up 2nd time if you able to get details could you please let us know when you can be able to provide feedback.
Yogaeasvaran
Greetings,
Kindly note that as we have not received any response from our previous follow-ups, we will be closing this request.
If you have any more questions in the future, please don't hesitate to post a new question, as this thread will no longer be monitored.
Yogaeasvaran
I am facing the same situation, I tried updating the firmware using the latest 9.52 version from here: https://www.intel.com/content/www/us/en/download/18190/non-volatile-memory-nvm-update-utility-for-intel-ethernet-network-adapter-700-series.html
The NVM update failed, and now I am not able to use the NIC. I tried the above steps to use the 4.42 version but getting this error:
With other versions the NVM update tool is showing Access error.
I am using this on Ubuntu 24.04.
